Post by cooldad on Oct 29, 2014 12:34:33 GMT
Made some alternater brackets as well.
Post by cooldad on Dec 1, 2014 12:07:06 GMT
If anyone is building one of these and hasn't fitted the floor I recommend you fit your side panels, then work out how much you need to leave hanging over the side to c over the gap between the side panels and the frame. You should also leave some hanging into the engine bay to pick up the side panel in the engine bay which has nothing to attach too.
Post by cooldad on Dec 1, 2014 12:12:49 GMT
Sam helping put the rivets in.
Post by kiwiev on Dec 4, 2014 8:02:34 GMT
Hi Keith
looking good, I trail fitted side pannels and they fitted fine to edge of frame how are you going to run brake lines and wiring with pannels on?
Also trail fit all your front hubs bearings and calipers you may have to machine off 6mm to get caliper and brake pads over disc . cheers Conrad
Post by richo on Dec 4, 2014 10:40:29 GMT
Hi Conrad. If you used cortina brake disks you will need to machine the calaper mounts. The best option is Rally design disks as they are the right diameter. They do cost a bomb to import to Aus though.
Post by cooldad on Dec 13, 2014 12:57:49 GMT
Thanks for the heads up on discs I should have checked this last week as I just ordered the discs. My side panels are just bolted on so I can take it off with minimum fuss anytime.
Post by cooldad on Dec 21, 2014 13:03:35 GMT
Finally got tie rod ends, they don't seem to fit. Too small for the large hole in the arm and too big for the spacers provided. They only go into the taper 4-5 mm anyone else have this problem?
Post by cooldad on Dec 21, 2014 13:09:19 GMT
Post by cooldad on Dec 21, 2014 13:16:48 GMT
Hi Conrad. If you used cortina brake disks you will need to machine the calaper mounts. The best option is Rally design disks as they are the right diameter. They do cost a bomb to import to Aus though. I'm curious is there a part number are they drilled and slotted? What about the rear does anyone know if you can get disk that fits a five stud 108 axel.
Post by airforceone on Dec 21, 2014 14:07:51 GMT
Normally you would just fit Focus/ST170 rear discs on the back as normal but as you are using newer 5 stud hubs you will need to check to see if the disc from your XR5 will fit along with the upright and caliper bracket.
There will be other manufacturers whose disc will fit it's just a matter of doing the research I managed to fid peugeot disc that fit on my Rocket and they were far cheaper than the Rally Design ones.
Post by kiwiev on Mar 5, 2015 11:13:54 GMT
Hi Keith
Long time no post how are you going?
I have found an engineer that will sign of sonic PM me if you need his details
cheers Conrad
Post by cooldad on May 24, 2015 5:24:55 GMT
Hi Conrad,
That would be great but will that work if I'm down in Tas. It's been a while had to put it all on hold for while while I did some real paying type work ha ah.
Post by Turbo on Oct 9, 2017 3:19:57 GMT
Hi
A quick question: which seats did you use? I assume they are ADR compliant. I have done som esearching for seats that will work in the Sonic and be ADR compliant but they seem to be too wide.
Thanks
