Post by jimmypatch on Jul 2, 2015 14:12:54 GMT
Hmmmmm Yeah I'm missing more than one item . Thanks for the picture
Post by jimmypatch on Jul 2, 2015 14:33:15 GMT
So I have deleted my abs I am now left with the servo and the balance device, where do I go from here? On side to the rear and one side for the fronts?
Post by R2S on Jul 2, 2015 15:36:08 GMT
So I have deleted my abs I am now left with the servo and the balance device, where do I go from here? On side to the rear and one side for the fronts? I bought a non abs servo, master cylinder, and balance valve from one of the forum members, Welsh 1, think it was about £30 all in including postage. Dont think you can use the one from the abs car but I may be wrong.
Post by jimmypatch on Jul 2, 2015 16:42:53 GMT
My servo has two outlets these go into the balance device this in turn then has two outlets, any ideas?
Post by marmot0 on Jul 2, 2015 16:45:27 GMT
There is a diagram in Stuarts build diary. cheers
Post by jimmypatch on Jul 2, 2015 17:13:01 GMT
I did look at the picture but it kind of does not make sense, it implies that the servo has three outlets or do you need a T junction, like most things on the build blog very little is explained.
Post by stevednorris on Jul 2, 2015 17:41:11 GMT
I've deleted my ABS and bought a non-ABS servo, master cylinder etc from eBay.
Post by jimmypatch on Jul 2, 2015 17:50:13 GMT
I think I may follow your lead Steve
Post by R2S on Jul 2, 2015 19:38:34 GMT
Heres the picture welshy1 sent me to help in fitting the servo he supplied showing where the pipes go. Send him a PM he may have one in stock.
Post by Stiggy on Jul 2, 2015 21:00:26 GMT
I did look at the picture but it kind of does not make sense, it implies that the servo has three outlets or do you need a T junction, like most things on the build blog very little is explained. The picture is correct. There are 3 as the rear pipe has a T on the donor at the rear subframe. Hope this helps.
