Post by Stiggy on Feb 28, 2015 9:30:14 GMT
what a brilliant idea for the fuel filler location! The dash needs spacers (40mm) to push it back far enough to get the wheels central to the arches. The body is then fitted tight up to the back of the bulge in the dash for the clocks. The drop plate for the column needs bending to suit your desired steering wheel height. Sometimes you may need to drill 2 holes if you find your chosen position results in the bolt slots being too short.
Post by jimmypatch on Mar 1, 2015 1:27:50 GMT
Yeah I need to enlarge that bulkhead hole too, I'm starting to think that this kit is not very plug and play, more like purchase and modify!
Post by jimmypatch on Mar 28, 2015 13:13:30 GMT
Where have you guys been mounting your front brake hoses? I was thinking of knocking up a bracket that attaches to the space frame chassis
Post by snowbird1 on Mar 28, 2015 14:15:22 GMT
I wish I had remembered to chisel the brackets off the donor so I made these up.
Post by jimmypatch on Mar 29, 2015 7:43:04 GMT
Thanks for the pic That's where I was thinking, but for the British IVA the bracket would have to be welded I guess
Post by jimmypatch on Mar 30, 2015 21:44:39 GMT
So I am now at the point where I'm nearly finished with the MX5 stuff and I'm ready to build the kit, So I guess I have loads of questions, I've noted lots of holes / mounting points on the chassis, now because there are no instructions with the kit I am really curious to know what they do! 1: there are two mount points on the floor where the seats will go, ? 2: there are two mounts near the floor just behind where the rear bulkhead will be?
3: there are two cylindrical mount points at the very top of the chassis?
Also are the original MX5 brace/strength bars, that go from Diff towards the front of the car, required?
Post by marmot0 on Mar 31, 2015 18:47:55 GMT
I riveted mine with no problems
Post by jimmypatch on Apr 13, 2015 21:31:59 GMT
Well I've finally sorted out the foot wells and the transmission tunnel. I guess I'll tackle the wiring after that
Post by jimmypatch on Apr 18, 2015 19:12:03 GMT
Post by R2S on Apr 18, 2015 21:25:53 GMT
jimmypatch photo won't load just get error code from photobucket
Post by jimmypatch on Apr 19, 2015 19:57:10 GMT
Ahh ok, what is the best way to get pictures into a thread?
Post by p5curly on Apr 19, 2015 20:23:24 GMT
Check out the notices and admin section it explains it there
Post by jimmypatch on Apr 20, 2015 22:06:09 GMT
Post by jimmypatch on Apr 20, 2015 22:22:46 GMT
Post by jimmypatch on Apr 22, 2015 13:02:10 GMT
So with regards to the rear body mounting bracket, where abouts are you supposed to drill the holes, does anybody have an acurate measurement? thanks
