Post by tr6ke on Jun 17, 2014 22:20:40 GMT
I'm looking in to options of towing my trike so I can take it away on holidays with my self and girlfriend. I'd never get away with surgesting driving it any distance before someone says that.
I've seen in the past a frame that fits on a towbar that the front wheel of a conventional trike drops in to but with the case of a reverse trike would this work??
Keith
Post by slugshot on Jun 18, 2014 0:03:56 GMT
Don't try towing with the rear wheel on the road unless you remove the drive chain or drive to the motor, you would probably scrape the bodywork (at least) if you tried towing it backwards.
I have a little trailer that's for towing smart cars behind motorhomes. its easy to tow even with a normal saloon size car.
Post by tr6ke on Jun 18, 2014 7:43:26 GMT
Thank you. I'd suspected as much. Plus may be safer as trike can be secured to trailer
Post by bluecob99 on Jun 18, 2014 12:14:58 GMT
Mate, get rid of your bird , you can go anyware your like then:) Cheers, Will
Post by Deleted on Jun 18, 2014 20:18:46 GMT
My wife doesn't like going out in my trike so she stays at home. Job sorted.
Sent from my Nexus 5 using proboards
