Post by Raj'sDad on Dec 24, 2014 2:39:48 GMT
Thanks ll of the pica Dave. I think iam going to have to get the side panels on to workout the skuttle fitting properly. If anyone else has any good pics on how the sonic skuttle(Rtr dash) is cut to fit, please do upload. Good days work today...managed to get a fair bit done...tank is nearly all prepped, hopefully is additional ally arrives tomorrow I should have that completed. Brake and clutch lines all finally fitted, ecu and all other fuse brackets made and fitted ready for wiring to commence soon main ally coolant pipes fitted also and can now begin to fit silicon hoses and rad tomorrow and seats shall go in tomorrow providing the runners are finally delivered, were due today, Dave - you also i see you have made a whole frame structure for the seats is all that really necessary for rigidity ?
Post by davef on Dec 24, 2014 16:22:53 GMT
Yes you are correct, you need to get the side panels fitted correctly, this will then allow you to fit the rear panel and the front grill, once they are all in place and you are happy with the shut lines etc then you will have the correct height for the scuttle. As for the seats, you must do whatever you think is necessary, I have engineered mine to be as secure as possible, in the event of a impact I don't want the seats breaking loose easily!
Post by Johnsto on Dec 30, 2014 15:17:41 GMT
Are you attending any meets/shows in 2015? Would be nice to see the car in the flesh.
Post by Johnsto on Dec 30, 2014 15:20:01 GMT
Also did you receive my reply to your message?
Post by davef on Dec 30, 2014 19:56:48 GMT
Yes John got your reply also I hope to be at several shows right through the year
Post by mawdo81 on Feb 23, 2015 20:05:26 GMT
How did you mount your fuel tank? Is it bolted directly to the floor? What hardware did you use? Thanks James
Post by davef on Feb 25, 2015 23:44:23 GMT
Hi James, I mounted the fuel tank directly onto the floor with two 5mm steel straps underneath between the chassis rails. Sorry don't have a pic. I used M8 bolts. Don't forget you need drain holes or a gap for spilt fuel to escape
Post by mawdo81 on Feb 27, 2015 13:28:00 GMT
Thanks Dave,
Could you please do me a favour and measure the size of the tank and where your steering column passes in relation to the bulkhead and steering mount points please?
I might get one custom made but need to know the original size and available width.
Re the steel straps - are they bolted with the bolts vertical or horizontal please? Is the bottom of the strap resting on floor?
Sorry for the questions, I'm just trying to imagine it.
I'm going to draw up my plan in something (not Solidworks!)...
Post by Johnsto on Feb 27, 2015 21:57:38 GMT
Hi James, This is how my Sonic tank sits. It is on 20mm nylon spacers. Hope that helps a bit
Post by mawdo81 on Feb 28, 2015 6:30:49 GMT
Thanks John, could you measure the tank size for me if you get the chance please?
Post by Johnsto on Feb 28, 2015 17:27:09 GMT
I'll measure the tank for you tonight.
Post by Johnsto on Feb 28, 2015 19:42:31 GMT
Hope this helps.
Post by davef on Mar 17, 2015 22:37:00 GMT
Today I left my car with Mark at Automotive Solutions & Racing, the next time I see it I should have an IVA certificate! Please please please .
cant thank Mark enough and can highly recommend him
Post by davef on Apr 1, 2015 15:24:49 GMT
WHOOOOO HOOOOO SONIC PASSED IVA!!!!!Many thanks to Mark at Automotive Solutions and Racing. My Sonic passed IVA today, getting her back tomorrow and will be registering her ASAP. Hope to bring it to Stoneleigh.One very happy bunny
Post by martinw on Apr 1, 2015 16:13:57 GMT
Excellent news Dave - it's a great feeling! Hope to catch up with you at Stoneleigh - yay.....another Sonic Martin
