Post by davef on Sept 27, 2014 15:55:31 GMT
Its been along time since I updated and have made good progress. The engine is in and running nicely, all the electric's have been tested and work ok. Minor issue with the coolant fan not cutting in but think this will be relatively easy to resolve.
Tunnel almost completed, just need to buy gaiters for the gear lever and handbrake, once everything has been double checked it can go back on the trestles, suspension removed to have the body fitted. Cant believe the attention it has had from the guys who live around me! My 1st December deadline looks tight but achievable. I will try and put some pics up soon
Post by davef on Dec 11, 2014 18:52:54 GMT
Well I didn't keep the build diary up to date as much as I would have liked to but I dropped the Sonic off at RTR this morning for its IVA.
Post by mawdo81 on Dec 11, 2014 19:24:51 GMT
Well now you have some free time you could bring us up to date?! ;-)
Post by davef on Dec 17, 2014 21:51:34 GMT
Post by davef on Dec 17, 2014 21:55:14 GMT
Trying to upload a few pics, but forgotten how
Post by davef on Dec 17, 2014 22:07:51 GMT
Guys any help please, I have been trying to update pics with using the url from photo bucket and the icon above but just get a little blue box and no pic?
Post by mawdo81 on Dec 18, 2014 13:02:00 GMT
Think you need to trim the ".html" from your src reference. That's what I've done in the quote above. Pic looks great,
Post by mawdo81 on Dec 20, 2014 9:36:47 GMT
Which blue is that?
Post by andybaird on Dec 20, 2014 11:59:26 GMT
Hi Dave
Looking good. Like that Blue.
Cheers Andy
Post by davef on Dec 21, 2014 14:24:15 GMT
I must be doing something really stupid as I have tried all morning to post some pics, fed up now and giving up. The blue is RAL5022
Post by davef on Dec 21, 2014 16:16:59 GMT
Think I might have sorted this at last
Post by Raj'sDad on Dec 23, 2014 8:16:07 GMT
Looking awesome..well done Dave, nice work.
Post by davef on Dec 23, 2014 20:40:17 GMT
Harminder, this is the Scuttle before its cut to fit, it doesn't quite reach the cross member Once you have fitted the side panels you will have the correct height to cut the scuttle. I don't seem to have a picture of the cuts in the side of the scuttle to make it fit. You can see from this picture that the scuttle just sits on the cross member, by about 10-15mm as you can see below there is not a lot of room to put the ECU here and it has to be fitted at an angle to make sure it does not foul the body, Another pic of the ECU fitting This is a picture of the scuttle before its cut to fit the main cross member, you can see it sits too high and not far enough forward I didn't drop the steering column or the pedal box, once tightened the box was hard up against the mounting. as you can see here If there is anything else you want to ask please do.
Post by mawdo81 on Dec 23, 2014 20:46:13 GMT
Dave is that the standard tank? Is the sonic tank different to the rocket one?
Post by davef on Dec 23, 2014 21:36:57 GMT
Yes standard tank from RTR but I think it is different to the Rocket, I think it is more rectangular (but I could be talking rubbish!!)
