Post by mrjingles705 on Oct 24, 2014 10:43:47 GMT
Post by mrjingles705 on Oct 24, 2014 11:05:38 GMT
A couple more details: 1) Fitted in all the rivet holes with RTV sealant between this and the tigerseal underneathshould keep water out 2) This is what the bridge plates will look lie when fitted - my M8's in 8.8 are too long (and can't be cut down because the unthreaded portion is too long itself) so need to get some shorter ones. Can't help thinking I should have angled my cut a little more but I didn't want to take out more material than absolutely neccesary. fig packet mockup said it 'should' clear the gaz shocks as is... but the proof is in the pudding so I won't know until it's all fitted up. Plans for this weekend include: 1) Making up the brake/fuel line brackets 2) fitting the bushes 3) cleaning up the old bolts I've chased my top mounts and they are still 1 week out.... so next weekend looks like the day to turn this back into a car (fingers crossed).
Post by gwnwar on Oct 25, 2014 5:49:28 GMT
You may want to round the corners on the cuts to keep the IVA man happy.. With the floor being water tight you might want to put in a drain hole or two per side with rubber plugs in them like OEM are.. in case you are caught in the rain and need to get water out..
Post by mrjingles705 on Oct 25, 2014 10:17:04 GMT
You may want to round the corners on the cuts to keep the IVA man happy.. With the floor being water tight you might want to put in a drain hole or two per side with rubber plugs in them like OEM are.. in case you are caught in the rain and need to get water out.. Yep, slept on it and came to the same conclusion. On the drain holes - yep, not a bad idea gonna wait until i habe tank, battery etc sited and then try and introduce a small bung per section.
Post by mrjingles705 on Oct 25, 2014 20:43:50 GMT
Ok, a few hours today so fab'd some brackets. First off, this one to rotate the rear brake splitter block without losing any support. Then onto the car to mock it up and check hose ok: (triangle tip will be squared off btw) Next, centre tunnel brackets for fuel x2, brake plus rear wiring ... Went a bit ocd on this and bent each bracket according to the trans cover angle to avoid any rubbing whilst keeping a gap to the Ppf Painted and drying - so put the bits together ready:
Post by p5curly on Oct 26, 2014 16:53:21 GMT
Are you fitting standard shocks
Post by mrjingles705 on Oct 26, 2014 18:21:17 GMT
Gaz gold pro's
Post by p5curly on Oct 26, 2014 20:17:05 GMT
You may need to trim the bones as it may catch the shocks when they are fitted in the frame
Post by mrjingles705 on Oct 26, 2014 20:30:45 GMT
Done the brace plate on the front wishbones - is that enough? Or are we talking more off than that?
Post by p5curly on Oct 27, 2014 10:35:17 GMT
The curved plate that you bolt to the wishbones may catch the shock when fitted with chassis we had to trim a bit off ours
Post by mrjingles705 on Oct 27, 2014 11:07:45 GMT
The curved plate that you bolt to the wishbones may catch the shock when fitted with chassis we had to trim a bit off ours how much? (do you have a pic?); can't trial fit mine yet as still waiting for my replacement top mounts (I've coverted to theMK 2 top mounts and suspension, not sure if this will help or not!). Also - have you got any pics of your brake/clutch plumbing on the bulkhead? I'm trying to tap/rivnut everything ahead of time before I drop the chassis over, but I'm struggling toget how the pipe is going to run from the side of the trans tunnel to the bulkhead without catching the bellhousing on the gearbox/wiring/clutch pipes etc. Don't have many pics of this from the MX-5 dismantle
Post by p5curly on Oct 27, 2014 11:32:31 GMT
I can email you some pics later if you like
Post by p5curly on Oct 27, 2014 12:50:34 GMT
Forgot to ask your email addy
Post by mrjingles705 on Oct 27, 2014 14:51:44 GMT
Forgot to ask your email addy PM'd it to you darren AT houldcroft DOT co DOT uk
Post by p5curly on Nov 1, 2014 22:41:33 GMT
Hey DAZ how's your build going when do you think you will have the body on
