Post by daveisom1 on Jun 3, 2013 19:53:05 GMT
Can anyone give me some details of what they have done with the fuel tank breathers. I have left mine as just the 10mm stubbs as per supplied but in hard cornering and pulling away I am loosing fuel at a vast rate. Looking at putting an extension on each but where to lead them or is there some sort of valve that can be fitted.
Post by Deleted on Jun 3, 2013 21:13:14 GMT
I was trying to find a pic of mine, but for some reason didn't take any of that part of the build. I ran a pair of one way breather valves on the end of a bit of pipe of each tank and the vent off at the back of my firewall next to my rear lights. Seem to work fine. Cost about £4 each
Post by edwinwl on Jun 4, 2013 5:10:51 GMT
With my tr1ke both stubs are connected to my swirl pot return. In both fuel tank filler necks i have drilled a small 1mm hole, for venting.
Post by daveisom1 on Jun 4, 2013 5:50:38 GMT
Thanks guys. I found some non return valve breathers on the old ebay last night so ordered them will then use a bit of flex to the light area, if it works for you sure it will be ok. Had extra stubbs fitted for swirl tank otherwise small hole in filler would have been ideal. Cheers
