Post by daveisom1 on May 19, 2013 18:51:09 GMT
Does anyone have a wiring diagram for the reverse motor, do I need a separate starter solenoid or is there one built in. Cheers
Post by Deleted on May 19, 2013 20:24:35 GMT
Well bench testing my unit today, I melted my switch, so I will need to rethink that now.
vtR1k
I'm a trike lover...
Post by vtR1k on May 23, 2013 18:54:04 GMT
I must have a diagram somewhere. When I am home in a few days I will have a look.
Post by daveisom1 on Jun 10, 2013 16:56:28 GMT
How do I use the neutral switch as an interlock for reverse. Have sorted all solenoids and switches but need to protect system by ensuring gearbox is in neutral.
Post by paulh on Jun 10, 2013 19:25:36 GMT
Hi Dave neutral indicator light is activated by a neutral( it has a permanent live ) so we have spliced in to the switched neutral which is then fed through the safety cut off switch then to the reverse button then fed to the coil side of a relay the other side of the coil has a permanent live. then on the switch side of the relay we have a permanent live to the common and the n/o contact connects to the reverse motor contactor. If you cant follow this let me know and we may be able to come down your way sunday if its not raining and you can have a look for yourself
Post by daveisom1 on Jun 13, 2013 17:37:33 GMT
Hi Paul. Thanks for the info. Got to admit I didn't look the other side of the neutral light. I will check out on the wiring dia and see what I can do. Would be good to get together some timw and compare notes. Will let you know. Will also pm you my tel and address. Cheers Dave
