mac
Newbie
Post by mac on Jan 27, 2013 21:46:46 GMT
Hello everyone! I am Anne from Rotterdam, The Netherlands. Soon my Eco-Exo-R will arrive and I will start building! I enjoyed reading a lot of build threads on this forum, but now it's time to create my own I have zero experience in building anything, so I am very excited to see how everything will go. Luckily I will have some help from a friend. We already started to take the donor apart. A 1999 Burgman AN 400 with 18.000 miles on it.
Post by jimmybcox on Feb 6, 2013 21:59:55 GMT
You can do it!
mac
Newbie
Post by mac on Feb 7, 2013 20:46:22 GMT
So can you! My kit will be here tomorrow :-)
Post by edvb on Feb 9, 2013 1:44:23 GMT
Good Luck Anne
I also was born in Holland and lived there 6 years before moving to the USA.
I am in the works of getting my Eco-Exo-R so will keep you posted.
If you have any electrical problems I am sure I can help you out.
Edward Van Belkom
mac
Newbie
Post by mac on Feb 10, 2013 19:47:28 GMT
That's just great to hear Edward. Also because I actually do have an electrical 'problem' ... When I bought the Burgmann it was running just fine. And waiting for the kit I actually enjoyed making a few trips on it. Last trip ended in heavy rain and a blown fuse (during driving it just suddenly stopped running, no strange sounds before that or anything). I was only a few kilometers from home, but it was definitely a great work-out to push it back . After a few days I replaced the fuse and it started again. Probably a short circuit due to the rain. I haven't seen a problem in the loom yet, but once completely removed I will inspect it more closely. However during dismantling I found two strange things in the electrical system. 1st this wire: It wasn't connected to anything, it has two connections that look like they can be used to bolt it to the battery poles. The other side looks molten, but strangely this 'molten' tip has no red in it. It ran from close to the battery underneath the body panels to somewhere near the engine. Quite thick cable compared to all the other ones (strange!). 2nd a cut connection tot the alternator/regulator (lower mid in picture, with some blue) The connection with the little blue part is connected to a bolt. In my Haynes manual there is no connection to this bolt. This bolt is most likely only meant to hold the regulator/rectifier to it's bracket. From the little blue thing there are two wires, one is cut and ends after a few millimeter and one runs to the white connector on the right on the picture (used for the headlights). It is connected to the black-wire-with-white-stripe. I guess that's the ground wire. On the picture you can also see that some black tape is winded around the later made connection (directly left from the white connector). I guess somewhere between 1999 and now someone created his own electrical masterpiece ;D, but what can be an explanation for creating this connection? (I am a mechanical engineer and have very little knowledge of electrics)
Post by edvb on Feb 10, 2013 22:16:02 GMT
Hi Anne
It is hard to see everything but most likely The red and black wires shorted in the rain and drained the battery and took out the fuse for the charging system.
I am getting a manual in a few days and my Kit should be here at the end of the week.
After looking at it I will be much more versed with helping you out.
Edward
mac
Newbie
Post by mac on Feb 11, 2013 19:38:30 GMT
I don't think the red/black wire had anything to do with it, it wasn't connected at all. It's been used for something and was later disconnected but not removed from the vehicle. Also it started on the battery after replacing the fuse. Battery wasn't recharged and also lights were still working when the fuse was blown. Today a package was delivered at work Very well packed, thumbs up for Scott!. The color of the panels is even nicer than expected. Also it's a bit smaller than I expected it to be, which I like!
Post by edvb on Feb 12, 2013 0:47:37 GMT
Hi Anne
Yes, it is hard to troubleshoot without all the factors and knowing what fuse blew.
I will have a manual in a few days and my kit late or early next week. Then I will be in a much better position to help you.
Wow did Scott do a great job packing that up!
I hope you take pictures of the unwrapping and to show what color your GRP panels are.
I was born in Tilburg by the way:)
Post by edvb on Feb 12, 2013 1:54:50 GMT
Double post.
Post by jimmybcox on Feb 13, 2013 1:25:18 GMT
Anne,
I suspect someone had a battery charger/maintainer connected at some time or maybe a stereo of some sort. Melted wires usually isn't a good thing and often caused by lack of proper fuse protection for the wiring. Fuses are designed to prevent conductor thermoelectric meltdown and fire!
Post by erik on May 15, 2013 15:18:59 GMT
Any progress?
mac
Newbie
Post by mac on May 15, 2013 21:23:48 GMT
Funny that you ask today, because after a way to busy time at work, today I went to the RDW (Dutch VOSA) for a VIN number. Als brought it away for powdercoating. Today also my second front wheel, brake disc and brakecaliper arrived.
So no real building progress yet, but there will be soon :-)
Post by erik on May 15, 2013 21:31:38 GMT
Ah, you are going the Dutch leglisation route. You might have a read through Rik's tR1ke thread to see the costs and effort going RDW route. You need to provide math of forces in the chasis as well which is a big problem.
I am planning to bring my tR1ke at end of june to RTR for MVSA. Should be much easier and cheaper.
What color sheme do you have in mind?
mac
Newbie
Post by mac on May 15, 2013 21:43:29 GMT
Good to know, they didn't tel me anything about the force calculations. (they also didn't tell me to bring the engine this morning, while I asked explicitly....and the invoices and ... etc.) I can always switch if I need to, will make sure to know these things in detail before having it tested.
Colors will be grey for the panel (lighter grey than one of the other builds) and black frame. I will add some bright red details with that. But I keep changing my mind on the colors...
Post by erik on May 16, 2013 16:17:16 GMT
Hehe, I even changed colors after I painted the front of my bonnet. Looking forward to see your progress!
erik
