Post by skyrangerman on Nov 26, 2012 0:34:41 GMT
Hi, Where do you fit the water temp sensor, does the engine(1.8)already have one fitted somewhere as i asume it had one in the donor or is it an extra that needs adding. Thanks Jonathan.
Post by veefour on Nov 26, 2012 13:43:42 GMT
Possibly the easiest place to fit a coolant temperature sensor is
to use a universal inline temp. sensor housing between your
nearside front to rear aluminium coolant hose and the original
zetec thermostat housing.
Post by skyrangerman on Nov 27, 2012 14:37:49 GMT
So the one that is already there as Mark said should keep the ford ecu happy, and I should fit one as Veefour said for the Vapor Dash. Does this make sense?
