Post by jimmybcox on Nov 17, 2012 19:40:26 GMT
First customer built Eco-Exo in the USA to commence soon!
Post by jimmybcox on Feb 6, 2013 22:08:39 GMT
Ok if I could just figure this out!
Post by Kevin Patrick on Feb 19, 2013 14:43:44 GMT
Post by Kevin Patrick on Feb 26, 2013 1:14:38 GMT
Post by Scott on Feb 26, 2013 11:39:31 GMT
WWOOOOOOOOOOWWWWWWWWWW !!!!  That look awesome !!! Loving the ideas,, keep them coming
Post by jimmybcox on Feb 27, 2013 5:14:01 GMT
Thanks Scott,
As you know I picked up the kit Thursday before last. I can hardly believe I'm just a few components away from the first test drive! All i need is a steering wheel adapter, a few specialty bolts, run the coolant lines, mount and connect the fuel tank and then a few hours wiring and I can drive it! So much fun I'm going to build it once tear it back down, paint it and build it again!
Seriously speaking the design of the vehicle is such that everything is just so easy to work on this thing could be built in a few weekends if your really a good builder. So far the tool i couldn't live without would be the large bench vise nothing else special beyond that save for the brake flaring tool which can be rented for $25 from Fed Hill. I used 12ft of Cunifer brake line SAE double flair with 3/16 line and two asian nuts. My total for the custom fitted hard brake line around 60 US
Post by Scott on Feb 27, 2013 13:29:05 GMT
Glad your enjoying it,, Im loving your ideas, it brings a hole new take on the trike,,, very impressed,,
I should be getting the Boss this week so will send it over asap,, can you email me the delivery address for it
info@eco-exo.com
Cheers Scott
Post by jimmybcox on Mar 4, 2013 4:38:58 GMT
Scott The new body design is really taking shape now 2.5 gals of body filler so far. Should be done with the body prototype by Friday then I can lay on the mold. I'll email the Address.
Post by Kevin Patrick on Mar 4, 2013 17:31:37 GMT
More photos from Jimmy: New keys:  Front end body shaping continues:  Stainless steel exhaust installed:  The nose is progressing nicely:
Post by Kevin Patrick on Mar 7, 2013 6:32:51 GMT
Post by jimmybcox on Mar 9, 2013 4:56:50 GMT
Arrrrrrrrrrrrr, Bondo bugers. I put on 4.5 gals of bondo and sanded off 3.5 gals
Post by jimmybcox on Mar 9, 2013 4:58:42 GMT
Notice Pink Panther on the foam board? Yeppers el cheepo form foam from Home Depot
Post by Kevin Patrick on Mar 12, 2013 9:14:03 GMT
Post by jimmybcox on Mar 13, 2013 3:43:52 GMT
Scott,
Thanks for sending the adapter so quickly!
Post by jimmybcox on Mar 13, 2013 3:50:04 GMT
Kevin,
Thanks for posting the pictures!
