Post by wayne1 on Nov 4, 2012 19:45:25 GMT
Hi,my sonic has passed it's iva but has has slight movement on rear wheels.2 new sets of wheel bearings later fitted by a garage and still movement any ideas.the car uses the 1.8 donor engine and drive shafts and new 25mm hub centric spacers or is this normal in other builds?
Post by andybaird on Nov 8, 2012 19:45:47 GMT
Hi Wayne
I also have a Sonic but I don't have much play in the bearings after the hub nut was tightened. Have you got the hub nut tightened up to the correct tightness.
Cheers Andy
Post by wayne1 on Nov 8, 2012 21:36:17 GMT
Thanks andy, yes they have been torque correctly I noticed when I was building the car that the rear wheels were floppyer than a sun hat until I torque them up and i thought they were fine but on closer inspection there was some very slight movement only 2 or3 mm of movement so I had a kitcar mechanic change the wheel bearings but no joy. I have used 2 spacer washers on each side of the drive shafts to push them further into the cvs,maybe this is the problem but it says to use them in the build guild.The mechanic said their not right but carn't give me an answer to the problem so don't no what to do next.
Post by andybaird on Nov 8, 2012 22:03:17 GMT
Hi Wayne
The other thing to check is how tight where the bearing going into the hub. If I remember there is two sizes off bearings for the donor. The part number for the bearings on my sonic is DWB1126 but I don't have the manufactures name. You parts supplier may be able to cross reference the number. Hope this helps.
Cheers Andy
Post by wayne1 on Nov 10, 2012 19:32:04 GMT
Thanks andy, I didn't know that there were two sizes of bearings,I though the ones I bought and watched being pushed in went in to easily.i'll try and buy 2 new bearings on that ref no and have another go.let you know how I get on but first i'm going to get to get it registerd next week.
