Post by Paul (madeye) on Nov 25, 2012 16:54:56 GMT
lol, i bet she has taken one out..
Post by pauljones915 on Nov 28, 2012 13:53:59 GMT
Camping hey mate,is that what you like to call it? nice look on the chassis paul,do i have to bring up some white gloves too? how about an all white pest suit to go in the mix.May have to take the lotus up this time, so i can pop over for the week end and swap my raw engineering skills and talents for a few brews.What you think?
While im on here,anyone have a spare wide band O2 sensor. Must be compatable with emerald k3/k6 ecu, Im feeling the need for more power mate..
Boys and their toys,enjoy "campin"
Post by Paul (madeye) on Nov 30, 2012 18:52:55 GMT
I've just seen it for the first time, the bar and powder was worth the money.... a lot of it
Post by bossman on Dec 4, 2012 18:43:11 GMT
i'm around this weekend paul if want to collect tyres
Post by Paul (madeye) on Dec 4, 2012 20:14:11 GMT
yes mate, you still on the same mobile number?
Post by bossman on Dec 7, 2012 10:45:03 GMT
I'm passing yours this afternoon Paul so i'll drop tyres off
Post by Paul (madeye) on Dec 7, 2012 11:57:32 GMT
i should be home around 4 mate
Post by bossman on Dec 7, 2012 16:12:17 GMT
I've left them at front of garage paul, one of them as got less tread on than i thought so £20 for the pair if you can use them?
Post by Paul (madeye) on Dec 10, 2012 21:13:57 GMT
got them mate, will do to roll the chassis round on, will need to be changed for iva though.. nearly build time for me... all smiles here
Post by Deleted on Dec 10, 2012 21:45:49 GMT
As a note regards to tyres for iva, dot and e mark is required, tread is not... sidewalls are also not under scrutiny. I suppose driving it to and from test maybe an issue regards to roadworthyness My r888s are sat nice and warm until I'm sure I won't damage them lol.
Post by Paul (madeye) on Dec 11, 2012 7:03:24 GMT
one of them is past the wear indicator at a point due to setup issues. but it will save me forking out for all new in one go. plus i can do as much wheel spin as i want when testing
Post by Andy on Dec 14, 2012 18:48:21 GMT
Hi Paul how's the build going Ta andy
Post by Paul (madeye) on Dec 14, 2012 19:50:45 GMT
Just finished a howling 10 week course, Monday is start date for bolting
Post by Paul (madeye) on Dec 18, 2012 22:18:42 GMT
a little progress made, all wishbones cleaned out and bushes and crush tubes pressed in. after a farce, wheel bearings pressed in the rears. (cheers for the info bob) everything greased up, ended up getting the skf bearings at a little extra cost as i didnt like the idea of the budget options. worst part to date has to be removing all the m4 button heads out of the chassis where they have been powdered over, it would have been easier to just tap them again. brake and clutch components ordered. all braided for hopefully less than a ton. just waiting for the hubs back from vapour now and i can get her rolling. i have made the decision to leave off the floor until the major work is complete so i can step in and out of the tubing. then lift the car into the air and get some pals to help offer it up from underneath, should be easier to do with the M4's holding it in and not rivets. ill update the pics when i get to grips with the new phone. Paul
Post by Paul (madeye) on Dec 18, 2012 22:50:13 GMT
right that just shows my skills with a mobile phone. ill stick to spanners i think
Bit over kill but just ordered 600 nylon washers
