Post by tr1kerfozzy on Feb 17, 2010 8:22:49 GMT
Post by nigel on Feb 17, 2010 20:09:02 GMT
Great Pic's keep them coming looks a quality build. nigel
Post by tr1kerfozzy on Feb 18, 2010 8:58:28 GMT
Post by tr1kerfozzy on Feb 21, 2010 11:38:30 GMT
Can anybody help with wheel choice?? I've been told the atomic/tR1ke hubs use focus 5 stud fitment will that be 5 X 108 and what ET do I need?
Post by tr1kerfozzy on Feb 21, 2010 11:41:33 GMT
Post by tr1kerfozzy on Feb 21, 2010 11:45:51 GMT
Rear light set up, outside Stop/Tail inside will be clear and indicators
Post by Stiggy on Feb 21, 2010 22:51:24 GMT
Can anybody help with wheel choice?? I've been told the atomic/tR1ke hubs use focus 5 stud fitment will that be 5 X 108 and what ET do I need? I would assume the hubs 2b 4 stud. I designed the geometry to accept the alloy uprights from rally design. To ensure the scrub radius is not high you will need an off set of 38-40mm. 15" wheels fit on those uprights. Avoid large diameter and wide tyres. The tR1ke is so light turn in will be great. Tyre pressures will need to be 20psi ish at the front. Zero camber and zero toe is a good place to start too. Ride height, kind of almost dragging on the floor. Well say 100mm. Any way thats all weeks off, or maybe not! Looking good. Stiggy
Post by roadtrackrace on Feb 22, 2010 6:46:02 GMT
You need 4 stud wheels Carl. 15"16" and 17" will all fit. 6.5" to 7" wide and et38-40.
We can still source the Momos if you want to go that way.
RTR.
Post by tr1kerfozzy on Feb 22, 2010 8:55:40 GMT
Yeah, sorry Paul, you guys just seem so busy I thought I'd try and sort some bits myself. I've got indicators, headlamps, stop/tail all sorted. Still not found a handbrake setup though.
So I need 4 X 108 38-40 offset.
Post by Stiggy on Feb 22, 2010 10:38:56 GMT
Post by tr1kerfozzy on Feb 22, 2010 12:17:24 GMT
Ok Stuart, so a 15" wheel with 195/50 tyre?
Post by tr1kerfozzy on Feb 22, 2010 12:28:32 GMT
Handbrake caliper ordered, thanks Stuart.
Post by tr1kerfozzy on Feb 22, 2010 22:16:04 GMT
Final wheel choice, had to have some black:
Post by roadtrackrace on Feb 23, 2010 9:48:40 GMT
Hi Carl
Just to let you know that RTR is also Top Gear Nottingham & Long Life Nottingham, so give Paul a call if you want a price on the above rims.
Cheers Leighton
Post by tr1kerfozzy on Feb 23, 2010 10:49:22 GMT
Thanks Leighton, I ordered them online so I could use up some of the Paypal funds generated by the sale of the R1 parts.
I'll be in to see the tR1ke this afternoon!! I'm like a kid at christmas.
