Post by sjf300 on Mar 18, 2012 18:35:49 GMT
Just wondering how far off the bottom of the tank people have been fitting Focus pumps in their Sonics or Rockets?
Thanks Stephen
Post by andybaird on Mar 18, 2012 18:47:08 GMT
Hi Stephen
I have my pump sitting on the bottom off the tank.
Andy
Post by sjf300 on Mar 18, 2012 19:14:18 GMT
Hi Andy
Thanks for the reply, but I thought as the inlet is at the bottom of the unit then a small gap might be required?
Stephen
Post by andybaird on Mar 18, 2012 19:34:19 GMT
Hi Stephen
The part off the pump that was molded to the inside off the Focus tank clips on to the bottom off the pump and provides enough off a gap for the fuel to enter the pump.
Andy
Post by sjf300 on Mar 19, 2012 9:39:57 GMT
Thanks Andy
I will not be using a donor car so do not have the clip on part, have you got an idea how far off the bottom it spaces it up, I was going to try about 5mm?
Stephen
Post by andybaird on Mar 19, 2012 16:51:41 GMT
Hi Stephen
The 5mm gap should be ok
Andy
Post by sjf300 on Mar 19, 2012 23:28:24 GMT
Cheers Andy
Post by frozenrabbit on Apr 29, 2012 11:08:55 GMT
im struggling with how to wire up the fuel tank if anyone can help, i dont know which wires go to sender unit, or ones that are positive from battery or earth any help please?
