Post by jonb2010 on Mar 4, 2012 21:41:22 GMT
I've just been trying to dry fit my fuel tank to make sure I haven't put the cooling pipe in the wrong place and having a head scratching moment. From looking at other pics the filler pipe should go between the two chassis members. Mine doesn't seem to go through them or below them. Have a look at the pics below and tell me I'm being stupid please.
Post by nigel on Mar 4, 2012 21:52:31 GMT
Cut the tank filler pipe down accordingly nigel Attachments:
Post by jonb2010 on Mar 4, 2012 22:05:01 GMT
Oh you cut yours that far back. Looking at this build then the filler pipe must be at a different angle as it fits between the chassis.
Post by andybaird on Mar 4, 2012 22:15:12 GMT
Hi Jon
I didn't want to cut the filer neck to much that it was lower than the top off the tank. I put a dent in the filer neck for it to clear the inner chassis members. I also had to cut some off the lugs at the bottom of the tank so that the tank can move a wee bit to the n/s off the car and butts up to the bottom chassis member. There is some photo's off the filer neck in my build thread.
Hope this helps Andy
Post by avantkiwi on Mar 15, 2012 20:48:44 GMT
Had the same head scratch. As per the other answers, you will need to cut the neck down.
Post by jonb2010 on Mar 17, 2012 19:42:21 GMT
Had the same head scratch. As per the other answers, you will need to cut the neck down. I cut 90mm off it in the end to get it to go in.Need to fit the rear bulkhead before I fix it in though. On your rear bulkhead did you just have a flat sheet of ali or was it formed to go over the chassis cross member ?
Post by andybaird on Mar 18, 2012 1:03:22 GMT
Hi Jon
It was formed at the top with two folds to make a channel but not to go over the chassis cross member. The formed higher up than the cross member for the engine cover to rest on.
This was formed and cut to the right height by MEV.
Post by jonb2010 on Mar 18, 2012 1:19:23 GMT
Hi Jon It was formed at the top with two folds to make a channel but not to go over the chassis cross member. The formed higher up than the cross member for the engine cover to rest on. This was formed and cut to the right height by MEV. Hope this helps Andy Oh bugger. I cut mine to size thinking that it was meant to fit over the chassis. How did you realise that it was meant to support the engine cover ? I've looked back through the build guide and I can't see a mention of it.
Post by andybaird on Mar 18, 2012 10:42:11 GMT
Hi Jon
I think it says in the order that the aluminium panels are cut to size so when it was above the cross member I looked at some photo's in other builds to check I had it right. I only had to cut out the area to slide over the box section on the floor.
Cheers Andy
outlander
" Drive it like you built it ! "
Post by outlander on Mar 18, 2012 12:06:06 GMT
The pic that you have shown was of my build, the pipe has been cut down to fit between the chassis rails.
Post by barry on Mar 24, 2012 21:03:43 GMT
I sure helps to look at pics of other builds on the forum to help with your build. I refer to it all the time.
Post by frozenrabbit on Apr 23, 2012 14:22:06 GMT
with mine i have just fitted the role bar but now i cant put the tank back in place, for it to fit the tank has to move forward or to the side so it is not hitting the role bar, when i do this the covers for the fuel tank do not fit as the tank is moved, im going to have to get a bit of my tank cut out unless anyone knows the reason for this?
Post by avantkiwi on Apr 23, 2012 15:40:40 GMT
If you are situating the tank behind the seat you will always have this problem. As it is the passenger seat, the loss of an extra inch should not really be of any concern. Photo of mine below:
Post by jonb2010 on Apr 24, 2012 19:56:03 GMT
I cut the top hole in my fuel tank in the centre as per the build guide but it doesn't leave a lot of room for the fuel gauge float to move around.
Anybody found an optimum angle for fitting the pump / float to allow full movement ?
