Post by jonb2010 on Dec 21, 2011 21:01:25 GMT
I've bought the Rally Design uprights from RTR and I'm waiting on the Hi-spec calipers. The problem is I don't know what discs to buy for the front. I've called Rally Design and they said that 265mm x 10mm should be ok but they may be 245mm. Not really what I wanted to hear Anybody sourced their own discs and know what size / fitting I should be looking for ? Jon
Post by Deleted on Dec 23, 2011 19:05:10 GMT
I bought a standard set of Ford discs and then had 40 grooves cnc'd into them. I was recommended to stick with grooves over holes, grooves dissipate heat very well without cracking between holes under extreme braking....
Post by airforceone on Dec 23, 2011 20:00:52 GMT
Post by jonb2010 on Dec 23, 2011 20:14:52 GMT
Thanks Ned, always there with the help I need
Post by jonb2010 on Dec 23, 2011 20:16:29 GMT
Do they do a drilled and grooved in that fitting ?
Post by airforceone on Dec 23, 2011 22:50:51 GMT
The first link is for the drilled and grooved discs, the description states x-drilled. but they have both holes and grooves. Have a look at my thread I'm sure I put pictures on there of the discs.
When I ordered them, there were pictures Of the discs, a one line description with no Picture is poor.
I got the info from the guys at RTR, helpful As ever, the usually have them in stock give Them a call.
As an add-on, I understand what venom means About having holes in the discs and causing possible Stress fractures. If you are using the car as a track car Then this might be an issue, with the constant hard Braking but for the majority of users these will last A long time.
Ned
