Post by Stiggy on Jan 8, 2012 23:24:08 GMT
Good work chap, I just posted info re set up in the tech section.
Post by stevieboy on Jan 8, 2012 23:53:35 GMT
Thanks stiggy
Post by stevieboy on Jan 10, 2012 13:45:12 GMT
I'm not near my car right now, so could someone let me know the rough max width and length of the ali floor panels on the exocet, only need maximum. Just looking at changeing something but i'm 2 hrs away and forgot to measure. Thanks guys
Post by Kevin Patrick on Jan 10, 2012 14:59:18 GMT
stevieboy - Mine are 21" wide and 60" long. So, ~533mm x ~1524mm.
Post by stevieboy on Jan 10, 2012 15:08:56 GMT
Thanks Kev, thats saved me alot of time and effort. Steve
Post by stevieboy on Feb 25, 2012 8:59:23 GMT
Well it seems ages since i last did an update, this is due to moving house and having no internet since Jan 14th, got it back last night. Have now fitted the floor and mounted the frame onto chassis, got the front corners on and most other bits are now ready to fit, will post photo's after todays efforts at fitting tank, finishing driveshafts and rear corners, and attaching fuel lines to underside. Hopefully still on for first drive to stoneleigh show.
Post by John B on Feb 25, 2012 23:00:24 GMT
Keep up the good work mate. Looking forward to seeing the pictures of the brake and fuel lines in place. Are you still planning on using the std mx5 fuel lines?
Post by stevieboy on Feb 26, 2012 8:00:19 GMT
Hi john, original fuel lines and plastic hangers are fitted to the inside bottom frame rail, drivers side opposite the ppf, also the electrics are going to run from front to rear via the ppf. This is the original route that the battery leads took on the mx5. Steve
Post by stevieboy on Feb 26, 2012 8:22:58 GMT
Well she's moved on a bit since last update, ready for getting it down onto just the jacks and taking the a frame away for good
Post by stevieboy on Feb 26, 2012 8:26:55 GMT
Post by stevieboy on Feb 26, 2012 8:30:29 GMT
Got the gearbox cleaned up and mated back to engine
Post by stevieboy on Feb 26, 2012 8:31:48 GMT
Post by stevieboy on Feb 26, 2012 8:37:43 GMT
Rear end is coming on well, hubs have been pressed off the driveshafts and relubed so fingers crossed if there is a future problem they should slip off far more easier now, they will be fitted next week when the full refurbish of the shafts has been finished
Post by stevieboy on Feb 26, 2012 8:44:52 GMT
Floor was time consuming but does look good, cut the floor pans out then pre covered them in vinyl fibre before fitting, i think it just takes the glare of the ally away without going over the top.
Post by stevieboy on Feb 26, 2012 8:53:35 GMT
Front corners are getting close to completion, need to check everything is tight then start with the nut covers and edge trim prior to wheels and guards
