Post by stevieboy on May 20, 2013 22:17:59 GMT
Need to chop the pipe back so there's more area to play with, but have got something in mind, but will let you know on a later post
Post by stevieboy on May 23, 2013 7:02:59 GMT
If anyone is in the position to measure the gap from top of tyre tread to underside of wing stay, i have bigger wheels so have to modify the length of the stay bars, but i need something to work to please.
stubbers
Exocet Number 306
Post by stubbers on May 23, 2013 8:45:32 GMT
Wont bigger wheels throw your spedo out for the iva, My method would be to get a tube the internal diameter of the outer diameter of the stay. Cut the stay slide the tube over then weld it.
Rich
Post by stevieboy on May 23, 2013 9:12:22 GMT
No the spedo is 0.01 mph out...checked on the maitia tyre/wheel size calculater site.... the problem i have is that they are very wide so i have to chop a piece in to the stays to swing them inward slightly, at the moment they are about 3mm from the top of the tyre tread which i dont think is right and also touching the tyre wall. What i need is someone with the standard setup to measure the gap between top of tyre to underside of stay, then all i have to do is modify them.
Post by Stiggy on May 23, 2013 9:41:55 GMT
Coming on very well Stevie, I would aim for 15 mm clearance, they do bounce slightly.
stubbers
Exocet Number 306
Post by stubbers on May 23, 2013 9:46:09 GMT
My gap between the wing stay and tyre is approximately 12.5 mm (not the easiest thing to measure accurately)
Rich
Post by stevieboy on May 23, 2013 11:19:18 GMT
Thanks guys, that helps alot, should get them sorted this weekend, not much left to do now.
Post by stevieboy on May 27, 2013 18:28:00 GMT
Calling Gwnwar.... ok coming to the finish now, but can start and everything, have no ignition lights so iva fail. everything works except the lights, wasted so much time this weekend on this so any help would be appreciated.
Post by gwnwar on May 27, 2013 20:10:16 GMT
Steve, Do you mean the eng ck, seat belt, charge lamps?? All other gages/lamps work.. Do you have a wire printout.. You have a 1.6 what year..
Post by stevieboy on May 27, 2013 22:34:03 GMT
Hi Gwnwar, got flashers, hazards, main beam, oil pressure, ect. 1.8,starts ok just does not show ignition lights
Post by gwnwar on May 27, 2013 22:49:35 GMT
Steve, What year is your car.. Are you talking about the Battery/charge light or the check engine light..
Post by stevieboy on May 27, 2013 23:20:15 GMT
Gwnwar, its the check lights on the first turn of the key, the car is a 1994.
Post by gwnwar on May 28, 2013 4:46:19 GMT
OK.. charge/battery, seatbelts, check engine all get power to cluster pin 2k B/Y from the meter fuse 10A.. charge/battery other wire is pin 1G W/B from alternator..
seat belt other wire is pin 1B LtGreen from timer buzzer
check engine other wire is pin 1C Y/B from PCM/ECU
Have you checked the bulbs, foil run on cluster board. use OHM meter to check each wire from start to gage cluster..
Post by stevieboy on May 28, 2013 12:20:00 GMT
Cheers Gwnwar, will try when i get chance after work, will keep you informed. As ever you are a great help to all builders on this forum, your knowledge is outstanding on the mx5. Thanks Steve
Post by ecowindman on Jun 30, 2013 23:00:33 GMT
Hi any update on the rear frame . How is it comming on. Dose it look good
Geoff
