Post by jonb2010 on Nov 27, 2011 11:27:23 GMT
I'm buying a new 2.0 Zetec engine which comes with a clutch and flywheel. I was thinking it would be better to use the lighter 1.8 flywheel but does this mean I have to buy a different clutch ?
If so anybody got any good links for them ?
Post by airforceone on Nov 27, 2011 11:30:14 GMT
Hi Mate
Unfortunately you can't use the flywheel or clutch from the 2.0 litre engine if you are using an IB5 gearbox. You need need a 1.8 engine flywheel and clutch set, the good news is that the 2.0 litre flywheel will get you 20-30 quid and the 2.0 litre clutch set will get about 50 quid on ebay.
Get a 1.8 flywheel from ebay about 20-30 quid, or go to a scrappy.
A 1.8 clutch kit (2 piece will set you back about 80 quid or 3 piece about 140) from fordpartsonline.co.uk
Ned
Post by jonb2010 on Nov 27, 2011 11:40:59 GMT
Thanks for the info Ned
Post by jonb2010 on Dec 2, 2011 21:29:40 GMT
Have you got the url for the ford parts site as I can't find fordpartsonline.co.uk ?
What is the extra part you get in the 3 part clutch over a 2 part ?
Post by airforceone on Dec 2, 2011 21:46:29 GMT
This is the site I used. www.fordpartsuk.com/shop/c/clutch_components_475/You need the two piece kit for the 1.8 engine which costs 71.36 I also bought a new clutch cylinder and bearing for an IB5 gearbox which cost 53.21 If your happy with the condition of the cylinder you have then you don't need to get one I just decided to by all new so shouldn't need to change anytime soon. Don't fancy taking the engine and gearbox apart again once it's in there. Ned
Post by jonb2010 on Dec 3, 2011 7:49:44 GMT
I've not got a donor and going all new parts so I'll need the 3 part.
moz
Junior
Post by moz on Dec 3, 2011 20:40:17 GMT
hi ive still got the genuine ford concentric clutch slave cyl if you want it £30.00 plus postage or pick up holmfirth area cheers
Post by jonb2010 on Dec 4, 2011 19:56:30 GMT
hi ive still got the genuine ford concentric clutch slave cyl if you want it £30.00 plus postage or pick up holmfirth area cheers Hi Moz is that a new part for a 1.8? If so I'll have it off you. cheers Jon
moz
Junior
Post by moz on Dec 4, 2011 20:07:56 GMT
yes it is how do you want to do this you can send me a pm if you like
Post by jonb2010 on Dec 9, 2011 20:58:15 GMT
Do I need a starter motor from 1.8 as well ?
