Post by skyrangerman on Nov 10, 2011 23:29:08 GMT
Does anyone know which hubcaps will fit the alloy hubs that come with the Rally design uprights,so as to keep the muck out and the grease in. Thanks
Post by daydreamer on Nov 11, 2011 0:07:35 GMT
Hi If these are the hubs you are thinking of then this is the grease cap that I have ordered. www.rallydesign.co.uk/product_info.php?products_id=13598I found them to be a very tight fit, so much so that I have not fully fitted them yet just in case I have to reassemble the upright. It would be worth a call to RD to check that it is the right part for your hubs. A search on google for "cortina bearing cap" will turn up lots of options, some may be cheaper than the RD alloy option.
Post by airforceone on Nov 11, 2011 5:52:24 GMT
I had these included in my alloy upright kit when I purchased them with my kit. Also depending on which kind of alloy wheels you buy, these may not fit or be needed I just put a small freezer bag over the hub and secured it with a tie-wrap just to keep the dust out.
Ned
