Post by skyrangerman on Nov 4, 2011 23:35:13 GMT
I am using rally design front uprights and powerlight calipers but when assembled my discs are not in the centre of the calipers. Which is the best way to correct this, space out the back hub bearing with washers on the stub axle or space out the stub axle from the upright. Any one suggest the best method. Thanks.
Post by airforceone on Nov 4, 2011 23:50:00 GMT
I had a slight misalignment with the passenger side, so put one of the supplied spacers on the stub axle, just needed the one now it's perfect.
Also the Rally design brake discs seemed to bind slightly with the caliper so used some M10 washers between the caliper and the bracket just to move it out a millimetre or so, worked at treat.
Ned
Post by wayne61np on Nov 19, 2011 20:49:03 GMT
Hi, I had the same problems with my sonic and i am now having problems with the wing stays. problem 1 they touch the wheels, problem 2 because the alloy uprights are not upright ie they tilt backwards if i fit the wings as it is, the rear part of the bracket would about 4 inches from the rear of the wing and the front one would be about 10 inches the front of the wing and it just looks so wrong, have any of you 2 got the same problem.
Wayne
Post by airforceone on Nov 19, 2011 21:45:01 GMT
Need some pictures of your problem just to clarify it. Take a look at my build thread I have some pictures of the front set up, let me know if yours is different as I don't have my wheels on yet.
Ned
Post by wayne61np on Nov 21, 2011 22:17:18 GMT
Hi Ned i can't seem to locate your pics, i have now modified my wing stays,and i will try and get a picture as soon as posible. would love if possible a brief idea of how to start a build thread with pictures as the car is not far from completion,but i am not that computer literate.
Wayne
Post by jonb2010 on Mar 17, 2012 20:43:04 GMT
I had a slight misalignment with the passenger side, so put one of the supplied spacers on the stub axle, just needed the one now it's perfect. Also the Rally design brake discs seemed to bind slightly with the caliper so used some M10 washers between the caliper and the bracket just to move it out a millimetre or so, worked at treat. Ned My discs are also misaligned so need some spacing behind. Is there a technique to get the disc and hub assembly off ? Are the spacers the thinner or thicker washers that come with the uprights ?
Post by jonb2010 on Mar 21, 2012 23:36:26 GMT
I had a slight misalignment with the passenger side, so put one of the supplied spacers on the stub axle, just needed the one now it's perfect. Also the Rally design brake discs seemed to bind slightly with the caliper so used some M10 washers between the caliper and the bracket just to move it out a millimetre or so, worked at treat. Ned My discs are also misaligned so need some spacing behind. Is there a technique to get the disc and hub assembly off ? Are the spacers the thinner or thicker washers that come with the uprights ? Anybody
Post by sjf300 on Mar 21, 2012 23:54:12 GMT
Try to measure / work out the misalignment and then use a gear / hub puller to remove the hub and then the bearing, fit a suitable spacer or washer.
Post by jonb2010 on Mar 29, 2012 16:13:33 GMT
Try to measure / work out the misalignment and then use a gear / hub puller to remove the hub and then the bearing, fit a suitable spacer or washer. Been and bought a set of gear pullers today from Machine Mart. Took me lo get to put the pullers together than it did to remove the hub so thanks for the advice Need to get the bearing off the shaft now but hopefully that won't cause a problem. What I have discovered though is that I don't have anything suitable to space it out with. Anybody got any suggestions what I could use ?
Post by sjf300 on Mar 29, 2012 19:00:45 GMT
Have a look in the technical section, RTR have revised the Rally Design upright build manual - now showing the shim that should be fitted.
