Post by skyrangerman on Oct 13, 2011 19:36:56 GMT
how tight should the crush tubes be in the nylon bushes, mine are a fairly tight hammer fit, i think collectively they will make the suspention too stiff, i can turn a smidgeon off the crush tubes but dont know how snug they should be.
Post by airforceone on Oct 13, 2011 19:55:56 GMT
My crush tubes are still a bit stiff even after running a 19mm reamer through the bushes, I imagine they will loosen off when I've got the wheels on and start to move the suspension arms around abit.
I have greased them up using teflon grease used for high performance bearings so should be OK.
Ned
Post by skyrangerman on Oct 13, 2011 23:18:50 GMT
so when you put them in what was the force needed to get them in. Thanks,
Post by airforceone on Oct 14, 2011 4:37:53 GMT
You should be able to use a rubber mallet to Knock them in, just put the arm on a work bench when you do it.
Ned
Post by avantkiwi on Oct 17, 2011 15:59:00 GMT
Your crush tubes should be Mallet tight. Remember to have plenty of Grease in them. I added grease nipples to mine so I can regrease/top up at any point without removing the suspension. There is a thread on this in the technical section.
