Post by Deleted on Jul 19, 2011 14:06:57 GMT
I have the Wilwood Master Cylinders and need an idea of the front and rear threads?
I have 2 x AP Pots with threads on that screw into the rear ports for the fluid in, but no idea what size they are as I need to make hoses up for them, or buy them?
And what are the threads for the fluid out, the ones at an angle?
Many Thanks
Nick
Post by latemarch on Jul 19, 2011 16:43:11 GMT
vtR1k
I'm a trike lover...
Post by vtR1k on Jul 20, 2011 6:03:30 GMT
By the way, the brake lines you can make yourself. I also did, it's very easy, but you must do it with care... These lines are also used in rally cars, so it's reliable. You need size Dash 3 for the lines from cylinder to calipers and size Dash 4 for the lines from reservoir to cylinder. And of course the correct adapter to screw in cylinders and calipers. www.qspraceware.nl/rubriek.php?topic=ENG_NippelremIf you want to I can look up what I used. You can see some pics of the braking system on my topic "Project started".
Post by Deleted on Jul 20, 2011 6:59:33 GMT
Many Thanks,
I have some spare bits n bobs, have made up some lines for the front ports with braided hose, but needed sizes for the rear. Cheers
Nick
