Post by flynn on May 23, 2011 19:05:44 GMT
Can people post up some close up for there Rad brackets and steering column supports please Thanks in advance
Post by flynn on May 25, 2011 0:09:56 GMT
Anyone?
mightylad
.....Mighty MEV Rocket.....
Post by mightylad on May 25, 2011 6:21:11 GMT
I think most of this is covered in the tech section! its a little buried though - happy digging!
Cheers,
Ol
Post by flynn on May 25, 2011 10:27:23 GMT
Dug and found a few bits, but was after some close ups.
Post by JimK on May 25, 2011 14:38:56 GMT
There are some close ups in Leicesterkev's build, let me know if these are ok or I can send you some images of mine. Regards Jim
Post by leicesterkev on May 25, 2011 17:59:38 GMT
Hi Flynn,
There is a close up of the bracket I used but can certainly send you some more pics if needs be. To be honest, I probably over complicated it a little but basically made my own from some cabinet brackets I got from b&q. Bolted them together, cut them down a bit and then drilled a hole through big enough for the Rose joint. Not overly pretty but seems to have done the job!
Give me a shout if you want me to send a few pics over though.
Kevin
