Post by skyrangerman on May 2, 2011 9:48:23 GMT
Hi all,
thinking of ordering my wheels for the sonic, TSW Rockets, just need to know if there is a certain offset that i require, or just as they come.
Cheers John.
outlander
" Drive it like you built it ! "
Post by outlander on May 2, 2011 10:24:43 GMT
Hi John
Front need to be 40 offset Rear need to be 15 offset with a 25mm spacer as per instructions (personally I used a 20mm spacer on the rear)
I hope this helps
jono
Newbie
Post by jono on May 2, 2011 11:02:10 GMT
Hi John, I have done the same as Mark, 40 at the front (Ford fitment) and 15 at the back (peugeot) and by a strange coincidence have also used 20mm spacers at the rear instead of the recommended 25 and all runs fine.
Cheers,
Jon
Post by skyrangerman on May 2, 2011 12:11:23 GMT
Thanks for the info, please excuse my ignorance but why the spacers instead of the correct offset wheel, ie 15mm offset rear plus 25mm spacer makes same offset as front, or have I got something wrong? Cheers John
Post by barry on May 2, 2011 19:29:59 GMT
Hi. I am using 0 (zero) offset at the rear and will probablly only need a 10mm spacer. I have 15 X 8 for the rear and 15X7 the front. Does one have to use a 40mm offset for the front? I am still building and learning as I go along so please excuse my ignorance!!
realtwin
Junior
Sonic 7 builder
Post by realtwin on May 3, 2011 12:04:00 GMT
Thanks for the info, please excuse my ignorance but why the spacers instead of the correct offset wheel, ie 15mm offset rear plus 25mm spacer makes same offset as front, or have I got something wrong? Cheers John Hi John the 25mm spacers allow you to buy fairly readily available wheels(Ford(40) and Peugeot(15)) with the same pcd 4 stud. A -10 (Correct offset without spacer) offset wheel will be difficult to find in 40 and -10 offset and will likely have a different dish on the outer. I have taken a different approach and have had some 50mm bolt on hub centric spacers cnc machined. I will have four pairs of these available fairly soon. It would have been this week if they hadn't got knocked about in transit coming back from the anodisers. They will be re anodised before I sell them. They come with new studs and bolts/washers for the hub and allow the use of 40mm offset wheels all round. Allowing for a better choice of wheels and you don't need to buy 25mm spacers. I'll get a picture on here today if I can. Andrew
realtwin
Junior
Sonic 7 builder
Post by realtwin on May 3, 2011 12:43:09 GMT
Here's a couple of images of what is in the kit. I will get more pictures of them on the hubs/wheels etc if needed and answer any questions that you have. I'm hoping to sell them delivered to the UK for around £170 all in. As mentioned it will be a couple of weeks till they are re anodised Andrew
realtwin
Junior
Sonic 7 builder
Post by realtwin on May 4, 2011 17:02:31 GMT
Hi. I am using 0 (zero) offset at the rear and will probablly only need a 10mm spacer. I have 15 X 8 for the rear and 15X7 the front. Does one have to use a 40mm offset for the front? I am still building and learning as I go along so please excuse my ignorance!! Hi yes you will need to use a 40 offset on the front in a 7x15. 10mm spacer sounds about right for the rear with an 8" rim. Andrew
