Post by airforceone on Jul 13, 2013 21:03:13 GMT
Looking to go away for the day with the wife 2moro.
If your back early enough next Saturday we could go for a pre-show spin.
Post by andybaird on Jul 13, 2013 21:14:59 GMT
Well you do have to give your second love some time aswell
Post by andybaird on Feb 16, 2014 14:11:21 GMT
Hi All
Been a few months from the last time I had the Sonic out for a spin so with a weekend off from work & DIY in the house I thought I would Check over the Sonic and go for a Run. The smile is back on my face.
Andy
Post by airforceone on Feb 16, 2014 15:33:51 GMT
Thought about getting out in the sun this morning myself Andy, but as usual pissed about too much and the rain started. Hopefully a sign of the weather to come.
Post by drbrian on Mar 10, 2014 1:42:34 GMT
Which set of spacers did you order, I need to order a pair tomorrow that fit concentric on the hub, so they don't get off center
Post by drbrian on Mar 10, 2014 2:14:11 GMT
Which set of spacers did you order, exact specs and vender would be greatly appreciated. I would like to order a pair that fit concentric on the hub, so they don't get off center. How is the car running? Thanks Brian G
Post by andybaird on Mar 10, 2014 17:09:55 GMT
Hi Brian
I would agree that the concentric spacers are best. I got them from e-bay. I don't have a record of the seller but if you look on e-bay you should find a set.
Andy
Post by drbrian on Mar 25, 2014 23:25:32 GMT
Hey Andy, Question, What size are the rear rotors on the sonic. I bought the wrong ones and now I am totally confused, check my posts in my feed Dr. Brian and comment their Thanks Brian
Post by robbiggs on Jun 7, 2014 10:29:53 GMT
Hi Andy Can you give me a bit of advice? How did you seal the all thread to the fuel pump top and bottom? What is the best way of sealing the pump to the top of the fuel tank? And finally did you have to alter the length of the inlet tube as mine currently touches the chassis? Regards Robert
Post by andybaird on Jun 7, 2014 11:03:42 GMT
Hi Robert
The seal on the thread I used small rubber round rings under the flat washers. As for the seal between the pump and tank I used the original seal from the Focus that I trimmed down.
As for altering the inlet Tub that was a bit of a pain. I didn't want to cut it down so that it was lower than the top of the tank but it would not sit flat on the floor with the filler through the side rails. I had to trim the tabs that bolt the tank to the floor so it moved the tank towards the passenger side of car then I also put a dent in the Inlet Tube as it passes the inner chassis rail to give it a bit more clearance. Hope this helps.
Cheers andy
Post by andybaird on Jun 7, 2014 12:22:22 GMT
Hi Robert Photo of tank before it went in to car. The Pen mark on the inlet pipe is where the dent was made around the other side to give clearance from the chassis rail. photo of tank under the body.
Post by robbiggs on Jun 7, 2014 18:42:08 GMT
Thanks Andy that's a real help. Regards Robert
Post by Raj'sDad on Dec 15, 2014 3:37:41 GMT
Where the cooling hoses runs past the exhaust, we have made them in Alu pipe and that is now fixed to the bulkhead. Flexible hoses each end will allow for engine movement. (we hope) From memory, in the rear we are using: 4 x 32mm 90 degree bends 1 x 32mm 135 degree bend 1M x 32mm flexible hose 1 x T piece (2 x 32mm + 1 x 19mm ) 1 x T piece (3 x 19mm ) 1 x 1M 19mm flexible hose 2 x 1M 19mm Alu pipe 1 x 0.5M 9mm flexible hose Do you know what pipes are needed for the front ? Trying to get mine ordered this weekend
Post by andybaird on May 27, 2015 20:56:11 GMT
Hi All
Not been on the forum as much as normal. Due to work I got the Sonic out for the first time this Year the day before Stoneleigh. Had to put it on charge to get it started so I didn't even get to take it a run. With all the work commitments at the moment I have decided to give the Sonic away. Don't worry it will only be away for a few day to get the engine changed over that I have been looking to do myself for the last 2 years. It is going to a mate that runs a small garage to get the work done.
Hope to be able to get a bit more time to get out in it.
See you all on the Scotland Road Trip Andy
Post by airforceone on May 28, 2015 16:19:00 GMT
Just been out today myself Andy. Started the car for the first time in about 8 months.
I went over to Dyna Tune in East Kilbride to sort out a problem with the engine struggling at low revs turns out it was just a fuelling issue so all sorted now.
If you want to give your car a tune after the engine change I would highly recommend giving Chris a call and going over for a stint on his machine.
