Post by blueash72 on Mar 25, 2021 18:18:34 GMT
For sale black 2018 g type with 1995 eunos import donor.It is a unfinished project which I may consider breaking so ppf,frame in black which has had some holes and fixings fitted to it,so if stripped there will be holes.loads of stuff including new radiator,gaz classic coil overs,cobra Monaco pro seats in fabric with cobra runners.Trs clubman seat harness In red.Brake callipers all round have been painted in red by BBC’s automotive.New brake cables fitted.Hel red braided brake hoses and 40mm bolt on spacers from freaky parts.300mm omp suede steering wheel with adaptor hub.Stainless steel exhaust manifold and complete twin exit stainless exhaust from mx5parts.Kn large induction kit cone air filter.New brake and clutch master cylinders.Suspension arms and anti roll bars have durables nanotechnology black bushes fitted to them.Subframes and suspension arms have been painted with por 15.The car was running a year ago but hasn’t run since.The wiring looms have been thinned out,but will require attention.Acewell 7659 dashboard also available and a new stamped chassis plate ready to be fitted to the chassis.All rubber boots replaced,ie cv boots and steering rack gaiters.Light set from MeV fitted but will require resistors fitting.Large car cover also with the car.As I said not sure wether I would sell as one or break up for the parts which have never been on the road.I think to sell it as a whole would be around £6000.The car is in Kent a mile from the M20 junction 4.
ian
