Post by bruciebonus41 on Jan 9, 2020 13:32:28 GMT
Post by bruciebonus41 on Jan 9, 2020 13:47:27 GMT
Next it was time to start cleaning up what was left. I was determined to do as much of this myself as I possibly could, so began the laborious (but oddly satisifying to me at least), process of clean, file, wirewheel, sand, paint, repeat. Started with the PPF, and the rear subframe
I also decided to swap out the diff and pick up a torsen. My donor had a welded diff, which was great fun for the weekend I drove it, but not something I could live with long term!! All bushes are being swapped out for the Energy Suspension kit I got from FreakyParts, and I managed to press out all but 3 of the bushes using my vice and a cheap tool that annoyingly broke with 1 wishbone to go. For the stubborn one I got the blowtorch out:
Post by bruciebonus41 on Jan 9, 2020 13:51:18 GMT
With the bushes out, I relented on the DIY approach for the control arms, and took them off to a powdercoaters in Eastleigh who did a cracking job
Pressing in the Energy Suspension bushes was a nice experience compared to some others I've fitted in the past, plenty of grease and they slide together with minimum fuss Note on the diff bushes for those using the Energy suspension kit. Keep the old diff spacer that sits on when you take the diff off the subframe, this will need to be reused.
Post by ritchie624 on Jan 9, 2020 13:52:02 GMT
Looking good mate. Solid start hope you manage to keep the pace up...
Post by bruciebonus41 on Jan 9, 2020 13:55:28 GMT
Post by bruciebonus41 on Jan 9, 2020 14:06:53 GMT
Post by bruciebonus41 on Jan 9, 2020 14:15:59 GMT
I got the message from Stewart that my kit was ready, and it was time to rent a van and get down there. Had a great time down at the factory, and spent an hour or so having a good chat and snoop around. Stewart is a great guy and managed to answer a lot of the questions I'd had. Got everything back home safely and into the garage.
Post by bruciebonus41 on Jan 9, 2020 14:23:12 GMT
Got the floors fitted at the weekend, fairly straightforward to do, spent a lot of time measuring before cutting and drilling any kind of the holes. After a thick run of tigerseal the floors were riveted into place. Next up is to run the fuel & brake lines, and then I can get the PPF back together and the chassis the right way up and facing the right way as it's currently sideways across the garage due to lack of space! A note on the fuel hoses, from one newbie to any others who might not have done this before, make sure you get the right type. I initially bought something that was fuel rated, but not the right pressure, and this was thankfully noticed by someone on the Facebook page before I started fitting it. Make sure you get something R9, I've bought 8 metres of this after returning the wrong one www.demon-tweeks.com/uk/codan-sae-j30-r9-high-pressure-rubber-fuel-hose-2008532/
Post by bruciebonus41 on Jan 9, 2020 14:24:07 GMT
Looking good mate. Solid start hope you manage to keep the pace up... Thanks Ritchie, I'm about 5 months in so far, so playing a bit of catchup on the post side of things!
Post by Stewart on Jan 13, 2020 22:57:16 GMT
Looking good! Keep the pics coming!
Post by bruciebonus41 on Jan 27, 2020 18:35:00 GMT
Post by garman on Jan 27, 2020 20:35:27 GMT
Nice progress! You are going to have a sweet Exocet when you are finished. Your color scheme looks great. You are taking the right approach with replacing seals and bushings while you can. Once you get it together you won't want to be bothered with small repairs. All you'll want to do is drive it. Keep up the good work.
Post by bruciebonus41 on Jan 27, 2020 21:37:55 GMT
Nice progress! You are going to have a sweet Exocet when you are finished. Your color scheme looks great. You are taking the right approach with replacing seals and bushings while you can. Once you get it together you won't want to be bothered with small repairs. All you'll want to do is drive it. Keep up the good work. Cheers Garman, so far it seems that a load of hours goes into certain bits and it doesn't look like much, then all of a sudden it all comes together and it's a big step forward.
Post by Stewart on Jan 28, 2020 10:01:50 GMT
Next up I'm going to get the brake system plumbed in, and need to find a suitable place to put the ABS cylinder, what have you guys done with this?
Post by bruciebonus41 on Jan 28, 2020 10:33:20 GMT
