Post by casesensitive on Jun 14, 2019 14:22:39 GMT
I'm selling my largely unused (because the car isn't on the road or track yet) filter. Pipercross PX600 90mm internal (120mm height external) domed sausage filter for fitting to backplate for individual throttle bodies or carbs. Never used on road or track, only test fitted a few times. Has two small imperfections about 3mm apiece, not visible from a distance. I needed something a little taller to accommodate new, broader airhorns/trumpets, so I've switched to the tallest one (120/150mm) ad still leave the recommended 19mm of gap. Recommend this for 70mm or shorter horns. Includes free DIY-cut backing plate spaced for jenvey throttle bodies on a blacktop/ST170, M14 hole for an IAT, useful template for cutting your own custom one, or you could use it in a pinch. €40 plus registered postage to you at cost, or you can collect from my house in the very unlikely case you're in Dublin for any reason :-)
