Post by The Joker on Sept 18, 2014 21:09:17 GMT
Hi Sammy,
Sorry for the delay. As mentioned in my PM to you; I have no plans just yet to produce a pedal in Aluminium but may do so in the future. I have too many other products in development at the moment,(non MEV). Standard pedals are available.
Thanks,
Post by sammy on Sept 19, 2014 7:12:09 GMT
Hello Joker, Ok, then I take a standard pedal. How do I get it? Please PM
Post by garymcp on Sept 19, 2014 17:27:28 GMT
Pedal received and a fine piece of kit it is! Cheers, Gary
Post by The Joker on Sept 19, 2014 21:53:14 GMT
Hi Sammy, You have PM.
Thanks Gary, glad you like it.
Post by duratec1999cc on Dec 4, 2014 19:52:33 GMT
Hi Joker, I would like to buy one of your quick shift kits, can you let me know what I need to do, thanks!
Post by duratec1999cc on Dec 4, 2014 19:54:21 GMT
I would like to buy one of your excellent pedal kits please, can you let me know what I need to do, thanks!
Post by The Joker on Dec 6, 2014 20:28:07 GMT
Hi duratec1999cc,
You have PM
Post by The Joker on Dec 6, 2014 20:28:24 GMT
Hi duratec1999cc,
You have PM
Post by bigalf on Jan 10, 2015 12:13:43 GMT
Hi joker.
I have pm'd you regarding shifter kit please
Post by howard on Jan 18, 2015 17:38:03 GMT
I now have a throttle pedal kits available for the Rocket priced at £27.50 + postage and packaging. The kit as supplied is pictured below and includes all the components needed to build and fit the pedal to the standard Rocket chassis. All you need to do is tap-out the pedal stop (M6) and the cable adjuster thread (if used), assemble, weld the footplate to the pedal arm and paint! The pedal is mounted to the strap that supports the brake and clutch pedal mounting via two M8 bolts, (supplied). Assembly instructions are included. For builders that have not yet had their cars IVA’d I recommend that the leading edge of the pedal is profiled before painting to remove any sharp edges, even though the control pedals are exempt from the edge test. The throttle pedal design compliments the Wilwood brake and clutch pedals perfectly and is fully adjustable to suit the installation. Pedal travel to full throttle is 60mm when using the standard FORD throttle body, (measured at the footplate). (illustration to show pivot bearing)Pedal fitment to the Sonic chassis is also possible. Kits are normally in stock and can be despatched within a few working days of cleared payment. Please contact me by PM for further details. hi joker looking for one of your throttle pedals to fit a sonic onto the wildwood pedal box
Post by casesensitive on Jan 26, 2015 15:37:01 GMT
Post by airforceone on Jan 26, 2015 18:05:34 GMT
The venhill kit comes with a load of stuff for fitting it.
I would wait to it turns up before buying anything else, possibly save some dosh.
Post by casesensitive on Jan 26, 2015 20:51:30 GMT
The venhill kit comes with a load of stuff for fitting it. I would wait to it turns up before buying anything else, possibly save some dosh. Normally I would, but because my UK delivery address cost €4 per delivery, and the clevis was £4, I just added it to the £300 order.
Post by casesensitive on Jan 26, 2015 20:53:47 GMT
BTW, turns out you can customise the colour of them, and on the spur of the moment I went for red for the throttle cable and yellow for the coward-pedal lines :-)
Post by nate78 on Jan 31, 2015 12:37:39 GMT
Joker- I've pm'd you
