Post by Stiggy on Dec 22, 2010 16:40:17 GMT
Don't try this at home! I decided to modify Julies MX5 loom for her Exocet, amazing how much weight and rubbish you can get rid of, you need to be brave however. I cut the wires one at a time and checked everything worked everytime I snipped one. Easy to get caught out and find the gauges have gone dead or the hazards start to flash slowly when they are switched off! I also found that you cannot leave the wiper switch off as the indictors feed via it. So I cut the stalk off instead. Def not a job for the faint hearted. I would advise to leave well alone unless you are experienced at auto electrics. I found you need to remove all tape first to show if cables are joined half way up the tubing which a lot are! Picture is of me screaming after I cut the loom with an angle grinder when taking the air con out in haste. Attachments:
Post by Kevin Patrick on Dec 22, 2010 18:07:27 GMT
The Medusa Stiggy!
Sounds like a hellacious task. How much weight do you think you saved?
Post by sscrow on Dec 22, 2010 19:14:26 GMT
Stuart,If I drop my loom off on Christmas eve , when could you have it sorted by?
Post by dinosaurjuice on Dec 22, 2010 20:47:14 GMT
eeek. brings back my wiring memories. dont fancy going there again
Post by Stiggy on Dec 22, 2010 22:58:54 GMT
The Medusa Stiggy! Sounds like a hellacious task. How much weight do you think you saved? I did well, I think the sweating was at least 10kgs
Post by Stiggy on Dec 22, 2010 22:59:42 GMT
Stuart,If I drop my loom off on Christmas eve , when could you have it sorted by? Sorry, I promised by shrink I would not do another
Post by Stiggy on Dec 23, 2010 9:09:29 GMT
eeek. brings back my wiring memories. dont fancy going there again Luckily the diesel Exocet only smokes from the rear and not from the loom. Attachments:
Post by Stiggy on Dec 24, 2010 12:41:17 GMT
Finished, no way am I going to do that again, nearly 2 days work, many thanks to Neil for his help. Attachments:
Post by Deleted on Dec 27, 2010 13:51:58 GMT
made this mistake myself. tried to be clever and remove as much as possible. took out the aircon and blowers, windows and interior lights, only to find that the instrument cluster went dead! back tracking, cursing and soldering for an afternoon replacing most seemed to sort the issue, but would recommend leaving it as is! the half kilo isnt worth the wasted time!!
Post by fasteddie on Apr 15, 2011 17:37:27 GMT
I hope all you exoceteers have bought a haynes manual as it does make it very easy to remove unwanted wiring and if you make a mistake? Just go to the appropriate wiring diagram and rectify, simple EEEEK
Post by andychalmers on Apr 16, 2011 12:31:57 GMT
I've done this job a few times with rally car builds. You can save money by using what you have but it so much easier to start from scratch, plus with these cars you need hardly any of the wiring compared to standard cars.
