Problem
Jul 28, 2017 22:43:29 GMT
via mobile
R2S likes this
Post by tojeiro on Jul 28, 2017 22:43:29 GMT
Feeling mighty chuffed that I finally managed to get ready to mount the body. Fitting process consisted of driving out one side of the garage and reversing back in under the shell, was just a case then of lowering down with my winch. Was all going so smoothly until this (null) by -Tojeiro 74- by -Tojeiro 74-Body is central over wheels and even if a shifted it fully back the rear brace would still never fit. Must be at least 100mm too long. by -Tojeiro 74-Guess I will need to break out the big hammer and welder.
Post by gwnwar on Jul 29, 2017 3:32:56 GMT
Really like that black.. and the wheels..
Post by Deleted on Jul 29, 2017 11:20:23 GMT
As you have discovered you will need to modify the rear supports. Best guess is they fit the no door version but could be wrong. This is kit car building :-)
Post by R2S on Jul 29, 2017 15:53:43 GMT
Original bodies were indeed longer but not by that much, i think Stuart said 50mm, but I may have misheard.
