Post by eman on Apr 14, 2017 17:05:59 GMT
I bought this from a previous member but now have no use for it. it is a low mileage 1.8 , 56000 miles The wishbones look to be in great condition with very little rusting, making them ideal for the kit! I think its a '99 car but can verify when back at the workshop. There is NO registration documents with this car, so it is transplant only. but if you have an MX5 that's rusty you could use the reg docs from that! Located in Herts. £300
Post by adamh on Apr 20, 2017 19:48:24 GMT
Hello, do you still have this?
I have a 1.6 with documents which needs a new engine. Do you know if it would be straightforward enough to use the docs from that with a different engine? Plan is to then use all the best bits across the two.
Post by eman on Apr 23, 2017 19:53:02 GMT
Hello, do you still have this? I have a 1.6 with documents which needs a new engine. Do you know if it would be straightforward enough to use the docs from that with a different engine? Plan is to then use all the best bits across the two. Cheers Sorry you just missed it. It sold on eBay and I won't say how little I got 😂😂
