Post by petes on Nov 25, 2016 18:47:28 GMT
Im replacing the 2 front ball joints on my Sonic which I understand are from a Maxi. The 2 I'm replacing have a rounded housing at the bottom of the ball joint. Ive ordered 2 replacements but whilst one is the same as those fitted the other has a parallel shapes housing at the bottom. I sent it back as being he wrong part and now received the replacement which again has the parallel housing. Im pretty sure both types will fit but is there any reason why I shouldn't fit one of each type?
Post by mawdo81 on Nov 25, 2016 21:05:18 GMT
What uprights do you have? For a while RTR changed to another style that weren't maxi that go with their steel uprights. I can look it up if you need...but the spindle size is way off so if yours seem to fit then this won't be the issue.
Post by petes on Nov 25, 2016 22:36:54 GMT
What uprights do you have? For a while RTR changed to another style that weren't maxi that go with their steel uprights. I can look it up if you need...but the spindle size is way off so if yours seem to fit then this won't be the issue. Cortina uprights. Ive just been in the garage having a closer look and I reckon they are just the same as the original ones other than the shape at the underside of the ball housing. Im just going to fit both of the new ones so its the same both sides.
