nigelblay
Junior
1999 NB Donor, 1.8 Engine, ordering kit soon.
Post by nigelblay on Jun 28, 2016 10:58:43 GMT
I'm now selling my MX5 Donor PPF as I've bought a mostly built Exocet kit from 'murfee' on this forum. I've done all the prep on this donor so you would have a good base to start building a kit. Here are the details and whats completed... 1999 MK2 MX5 with a 1.8 engine. Suspension... Subframes powdercoated black and wishbones powdercoated Kawaski green New Energy suspension bushes fitted New V8 Roadsters serviceable top ball joints and new lower Ball joints Antiroll bars powdercoated in green and new cobalt drop links New rear lower hub bolts (had to cut these off) All bolts have been cleaned and de-rusted Engine... Intake Manifold and Cam cover powdercoated green New cambelt and waterpump and all gaskets and seals changed Coolant reroute and new thermostat New Clutch fitted New plugs and leads Gearbox and Differential are cleaned and sprayed with silver high temp paint. I'm after £1000 for this but have £800 of receipts and then spent £400 on the powder coating and then the original donor so could save someone a bit of time and money here. The pictures below are not the latest so this doesn't include the wheels or exhaust manifold in the sale. I have some other wheels and spacers which I am selling seperately. This could be picked up in the back of a van as I've split the front and rear subframes so easily moveable and I have access to an engine lift if needed. I'm located in Bracknell, Berkshire and you're welcome to come and take a look.
Post by gwnwar on Jun 28, 2016 19:07:31 GMT
If you also have all the electrics and needed bits from the donor it is a good deal ready to go.. Why not put a post in the Exocet and Replicar sections.. See "For Sale Section" Listing for Running gear PPF Engine powder coated ready for frame to bolt on.. Please answer ask questions in For Sale section..
Post by scottmev on Jul 7, 2016 19:27:13 GMT
Hello there.
I am quite interested in the rolling PPF. Could you send me some latest pictures please as you sya they are not the latest in the thread.
Also I am presuming you have all the electronics and other parts required from the original donor - wiring harness, ecu and fuel tank etc.
If you could email me that would be great - scott.rankin21@gmail.com
nigelblay
Junior
Post by nigelblay on Jul 7, 2016 22:09:36 GMT
Hi Scott, yes I have all the other parts including wiring and ecu. I'll sort out some more pictures and email over the details tomorrow. Thanks, nigel
Post by scottmev on Jul 8, 2016 6:56:46 GMT
Many Thanks Nigel. Will keep an eye out for your email. Scott
Post by adamc on Aug 7, 2016 17:35:35 GMT
Nigel
Has this PPF been sold?
A
nigelblay
Junior
Post by nigelblay on Aug 8, 2016 13:40:57 GMT
Nigel Has this PPF been sold? A Hi Adam, no its still available. Email me direct on Nigel dot Blay at googlemail dot com as I can't do PM's yet. Thanks, nigel
