Post by R2S on Mar 19, 2016 12:17:29 GMT
Looking for some 3mm/4mm gasket paper, can anyone direct me to a supplier who doesn't charge the earth?
Post by gwnwar on Mar 19, 2016 19:58:34 GMT
R2S what are we making that you need gasket paper that thick??
Post by mawdo81 on Mar 19, 2016 20:15:49 GMT
There is some on eBay but I have no frame of reference for the cost!
Post by R2S on Mar 20, 2016 10:16:53 GMT
R2S what are we making that you need gasket paper that thick?? I am in middle of making alli spacer for clutch master cylinder (between cylinder and firewall), as pedal box sets the required thickness of the spacer I need to take up any difference between the sleeves on the pedal box and the spacers and want something that will have sufficient give. Thinner gasket may suffice but wanted to try thicker first.
Post by gwnwar on Mar 20, 2016 15:48:38 GMT
The adjustment rod should make up any difference there. Just need 10mm of free play at pedal pad..
