Post by WooDooUK on Feb 14, 2016 22:14:31 GMT
Hi Peeps, Our exocet recently failed its IVA partly thanks to the hot garbage that is these dominator headlights. I dont want to mess about chopping them up just to get them to a point where they might pass an IVA, i could really use something that will pass. Doesnt have to be pretty cheaper the better. Or recomendations for IVA Friendly Lights Thanks, Mark Based in South Wales. drop me a PM with a price if you have something.
Post by airforceone on Feb 14, 2016 22:38:46 GMT
What was the issue with the dominator lights.
My rocket passed with them along with loads of other kits that have used them.
The small photon lights seem popular but are quite expensive, I imagine any light similar to the ones westfield type cars use should be ok.
Post by Froggy on Feb 14, 2016 23:21:03 GMT
I've not long ago passed Iva with dominator lights, they were weak on the high beam test but that's only due to cheap bulbs, tough thing with iva is that it seems to depend on what station you use, Notts seems to be very realistic overall. Not many lights out there, and the ones available like the venom ones (think I've named the ones correctly I'm thinking of) are expensive and personally I think too big and not very pretty. Good luck with the retest. Wayne.
Post by ridgeback on Feb 14, 2016 23:33:18 GMT
Hi Where in South Wales are you?
I have a set of the oval Hellas lights on my Rocket they will definitely pass the IVA.
May be able to do a deal with you taking your dominators in exchange.
I I'm based just outside of Newport.
Post by kiwicanfly on Feb 14, 2016 23:41:40 GMT
It does seem very arbitrary with those lights.
What is the official reason for failure?
Post by kiwicanfly on Feb 14, 2016 23:56:36 GMT
Just found this on Car Builder Solutions.
Note: FLAT BEAM PATTERN Which may not pass IVA
Personally I think this is a real bad show either they sell conforming product or they sell non-conforming product for track/off-road etc. with a clarification.
"May Not Pass" - What a cop out.
Post by martinw on Feb 15, 2016 0:14:25 GMT
I *think* the issue with Dominators is that the beam isn't actually flat (ignoring anything about inferior bulbs and such like). It seems to me it's actually a very shallow parabola, so will give the impression of a kick-up to the offside unless you do something about it. A flat beam should be acceptable.
With a Sonic the need to modify by rotating the glass is not really a big issue as generally the lamps are mounted on a surface which isn't parallel to the ground, so some rotation is necessary anyway. With a Rocket only a few degrees should be necessary, but more of a pain to do I guess.
Martin
Post by WooDooUK on Feb 15, 2016 9:50:38 GMT
I *think* the issue with Dominators is that the beam isn't actually flat (ignoring anything about inferior bulbs and such like). It seems to me it's actually a very shallow parabola, so will give the impression of a kick-up to the offside unless you do something about it. A flat beam should be acceptable. With a Sonic the need to modify by rotating the glass is not really a big issue as generally the lamps are mounted on a surface which isn't parallel to the ground, so some rotation is necessary anyway. With a Rocket only a few degrees should be necessary, but more of a pain to do I guess. Martin Exactly this, the beam patten is not far off a LHD set of lights.
Post by WooDooUK on Feb 15, 2016 11:06:06 GMT
Hi Where in South Wales are you? I have a set of the oval Hellas lights on my Rocket they will definitely pass the IVA. May be able to do a deal with you taking your dominators in exchange. I I'm based just outside of Newport. That would be perfect as i am only in Caerphilly, Could you send me a PM as i cant start any PM conversations. Thanks
