Post by Kevin Patrick on Feb 8, 2016 15:44:53 GMT
Check it out! exomotive.com/exocet/off-roadStage 1 (current): Exomotive Exocet Shock Spacer kit + Paco Motorsport 3" Lift Kit + NB Bilstein HD Shocks + 154F/94R Springs. 15x8 JNC003 wheels with 30x9.5-15 Yokohama Geolandar M/T+. Stage 2 prototype parts in production at Paco Motorsports this week, estimated release this Spring. We're aiming for the Mitty at Road Atlanta to debut.
Post by Kevin Patrick on Feb 8, 2016 15:48:10 GMT
Post by papabear on Feb 8, 2016 16:47:52 GMT
Kevin,
Do you think the Paco Motorsports longer A-arms could be adapted to a track car? Or is the geometry set up for the lifted suspension angles? Longer arm and added track width would make fitting bigger track tires much easier.
Post by kiwicanfly on Feb 8, 2016 18:33:41 GMT
I like that but is there any way it can be made to be four wheel drive? I expect not but one never knows these days.
Post by greg on Feb 8, 2016 21:23:39 GMT
Decided this will be my DD Miatas future. We've had a couple snow storms this year that have convinced me I need this to get to work safely. No it doesn't make sense to buy a cheap 4WD truck. ....in my mind...
Post by pleurotus on Feb 8, 2016 21:38:48 GMT
I really, really like that. Got to have covered wheels over here (GB) though. I think...
Post by snowbird1 on Feb 9, 2016 14:47:54 GMT
Looks great, would be ideal for cruising the dirt roads around here but anything more serious I think it will tend to 'nose in' over the whoops because of the weight distribution. It will need a lower final drive with those big wheels - what is the lowest ratio available for the MX5? 4WD would be great, even for the road versions - the only practical way I can see is to make it a hybrid with electric drive to the front wheels.
Post by Kevin Patrick on Feb 9, 2016 20:54:33 GMT
papabear - Paco Motorsports has developed the kit for optimal off-road wheel frequencies, wheel rates, camber curves, bump steer, Ackermann geometry, and caster. My guess is that with the positions they may not correctly translate to a good street setup. Something to consider though! kiwicanfly - It would not be a trivial exercise due to packaging. I believe it will be best used a RWD prerunner-type vehicle. pleurotus - Our fenders fit over those Yokohama Geolandar M/T+ tires and we're looking at some modified fender mount designs so they can be installed with enough clearance. snowbird1 - It currently sits at 52%F / 48%R. Paco Motorsports has sourced a 5.38 ring and pinion and will bring it down to normal-ish Miata ratios. We're currently using a 4.3 Torsen from a '99 NB and a six speed from an '01+ NB. Works out to the following which is really not too bad, even with the 30" tires. GEAR RATIO MPH @7200rpm 1st 3.760 38.3 2nd 2.269 63.4 3rd 1.645 87.4 4th 1.257 114.4 5th 1.000 143.9 6th 0.843 170.6
Post by greg on Feb 9, 2016 22:23:59 GMT
papabear - Paco Motorsports has developed the kit for optimal off-road wheel frequencies, wheel rates, camber curves, bump steer, Ackermann geometry, and caster. My guess is that with the positions they may not correctly translate to a good street setup. Something to consider though! damn it.
Post by papabear on Feb 9, 2016 22:54:35 GMT
papabear - Paco Motorsports has developed the kit for optimal off-road wheel frequencies, wheel rates, camber curves, bump steer, Ackermann geometry, and caster. My guess is that with the positions they may not correctly translate to a good street setup. Something to consider though! damn it. I figured that was the answer. The geometry is all set for more a arm angle etc.. But looking at the arm drawing from Paco it may not be a huge redesign. But the market would be small.
Post by Kevin Patrick on Mar 16, 2016 19:56:13 GMT
Post by Trenon on Apr 13, 2016 23:19:18 GMT
Any idea on pricing for these kits?
Post by greg on Apr 21, 2016 13:47:51 GMT
Looks like FM took the 3" lifters off their site (or at least I can't find them). They don't have the "new" kit up yet but Paco was saying on Facebook that his target price was between $3k and $4K.
Post by Trenon on Apr 21, 2016 18:10:48 GMT
oh exomotive isn't going to sell them direct?
Post by trackjunkie111 on Mar 1, 2017 2:13:03 GMT
#65 is being built in the off-roadster right now. Picks to come. Paco kit on order already
