fatboy
Post by fatboy on Oct 10, 2010 12:10:09 GMT
Is it just me or is the wiring diagram in the haynes manual pap I am trying to work out wire colors and plug positions and they do not mach any comments
Post by nigel on Oct 10, 2010 14:23:55 GMT
Is it just me or is the wiring diagram in the haynes manual pap I am trying to work out wire colors and plug positions and they do not mach any comments The Haynes manual is a guide ! Ford like most other major car manufactures use what ever colour wire is around at the time of the cars build. The best thing to work to is connection Pin Numbers, however I have found the odd discrepancy in Haynes even on pin numbers. (Hazard switch springs to mind) If you run into trouble then post a question in the Technical Section, I know a few people on hear have got the Ford TIS disk and will help.
