Post by Stiggy on Aug 27, 2010 12:26:08 GMT
Short clips of the relativly easy process of preparing your donor.
Post by m4rky77 on Aug 27, 2010 22:04:29 GMT
I must literally be an hour away from the same job...................... shocking how quick it can be done
I've T cut panels, cleaned stuff and photographed parts for selling and it's still only took a day and a half !!!!!!
Post by nigel on Aug 28, 2010 6:24:27 GMT
Short clips of the relativly easy process of preparing your donor. I just can't believe how easy it looks Just to be sure that I understand correctly, are you saying that I need no special tools at all and that with just a standard Clark or similar engine hoist, that I can either buy or hire, I can split and remove the body shell ? and do I have to strip the car, to lighten the body, before I can remove it with the engine hoist ? nigel
Post by Stiggy on Aug 28, 2010 15:06:14 GMT
Had to laugh when I saw how black my hands were. The body weighs about 260kgs so it is an easy lift. I guess a strong guy on each corner could do it. Best to empty the tank first, then it balances easily. You can't take the tank out with it on the subframes. If a tank goes rusty the car would have to come apart to replace it. I took all the bits off first to save weight, they need to come off anyway to sell. You can get at the bolts holding the body on without going under the car. Just take the wheels off. I forgot to remove the engine earth on one car, as i lifted the body the whole chassis came up with it.
Post by trevbennett on Aug 30, 2010 8:57:48 GMT
Excellent!
I thought that once the bodyshell was removed, the chassis would drop to the floor, (because the top suspension mounts were unbolted, and would rise), but cant see any support under the chassis - so is it self supporting somehow? This would be great for me because I could still move the chassis in and out of the garage.
Cheers for now,
Trev.
Post by Stiggy on Aug 30, 2010 9:27:12 GMT
Well done for noticing Trev, you are correct the diff and engine would sink to the floor, BUT, I wegded a short tube between the top and bottom wishbones on each corner. They hold it up. The main battery cable can stay on. Just push it through the floor in the boot and leave it attached at the other end to the alty and starter. Regards Stiggy
Post by trevbennett on Aug 30, 2010 18:04:05 GMT
Very clever indeed - will remember that trick. Ideal for me to push the chassis around and not rush into putting the Exocet chassis straight on.
Trev.
Post by Stiggy on Sept 10, 2010 16:42:39 GMT
Just a piece of tube wedged in does the trick. Otherwise the diff and engine need propping up when you lift the body off. Attachments:
Andy888
Exocet Builder
Post by Andy888 on Sept 10, 2010 17:29:12 GMT
Ah that is very useful to know!! Thanks. Hopefully reach this stage next week stripping our 5.
Post by vmvcars on Sept 16, 2010 21:09:20 GMT
Now taking up a collection to get Stuart some Mechanix gloves
