Post by donboy1983 on Mar 4, 2015 23:23:43 GMT
Hello, This is a strange one but do people make copies of the Gaz shocks? The reason I ask is that I bought some last year brand new for my build and have noticed that they don't look as shiney and have a slightly different sticker on them. It's just me worrying no doubt but thought it would check what others thought. What I have Picture of the shocks from John and Luke's build.
Post by donboy1983 on Mar 4, 2015 23:31:35 GMT
It could be that the ones I have seen are not alloy so that will explain the lack of shine, has any one else got pics of there setup?
Post by jgilbert on Mar 4, 2015 23:32:13 GMT
Mine deffo came from Gaz.
Post by donboy1983 on Mar 4, 2015 23:38:16 GMT
Are your ones Gold Pros John? Not sure if the have another model.
Post by jgilbert on Mar 4, 2015 23:46:15 GMT
Good point, think mine are standard so you could have a different model
Post by donboy1983 on Mar 4, 2015 23:47:37 GMT
I will send them a quick email tomorrow to check and see what they say.
Thanks
Post by mrjingles705 on Mar 5, 2015 14:21:46 GMT
Mine: Yep, me and your brother are going to compare notes tmw Gaz gold pro Shocks ready to go on once platforns set and nuts nipped up (i'm using mk2 mounts and shocks); Possuible they have dulled off as they are sat? Aluminium will do that.
Post by thestig on Mar 5, 2015 21:17:26 GMT
What spring rates are you guys running on these? 350/250? Do you know what the mx150 racers are using?
Post by donboy1983 on Mar 5, 2015 21:44:13 GMT
Hello,
Right I have today emailed GAZ and they have advised they are genuine, now that's decided I can get them fitted.
the next question is how to fit? am I right in thinking that my first picture is the correct layout for the washers/topmount
Gaz Shock with both collars wound down Spring Collar on top of spring Rubber bump stop Large Washer Original Top Mount Small Washer Nyloc Nut
Post by donboy1983 on Mar 5, 2015 21:45:15 GMT
yes you are right the spring rate are 350 / 250
Post by exoRy on Oct 4, 2015 14:51:35 GMT
Sorry to bring up and old thread - is the order in your description and in the photo correct?
I'm just getting ready to put my gaz shocks together and want to make sure its right.
