Post by carlyd on Mar 14, 2015 10:10:50 GMT
I'm about ready to test fit the engine. I'm pleased with the look of it so far, and with the Honda power it should go as well as it looks.
Post by carlyd on Mar 14, 2015 10:11:31 GMT
Post by carlyd on Mar 17, 2015 12:17:28 GMT
I attempted to dry fit the engine to take measurements for custom driveshafts and gear selector cable etc but decided it will be easier when I get a mate round to help guid the engine in as I don't want to damage any powder coating.
I am now working on the brake bias with the willwood pedals as I want to get them fitted. I have read the various build threads and I understand the concept of brake bias but people seem to be using different bias settings. I've seen 1.2:1 (jacksdad) through to 3:1 front to rear. I know Jacksdads build isn't complete yet so I was hoping someone who has completed their build and has used the brakes could offer some advise on the best setting for brake bias please?
Thanks in Advance.
Post by bossman on Mar 20, 2015 15:48:02 GMT
Hi Carl. Looks like your making realy good progress, i might be going out for a run your way on sunday (weather permiting) was thinking of calling into to see you if your about?, PM me your details and i'll be in touch. regards John.
Post by carlyd on Mar 21, 2015 23:31:08 GMT
Hi Carl. Looks like your making realy good progress, i might be going out for a run your way on sunday (weather permiting) was thinking of calling into to see you if your about?, PM me your details and i'll be in touch. regards John. Hi John, it'd be great to meet you but I have family commitments on Sunday. Let me know next time you are out my way though
Post by bossman on Mar 22, 2015 0:02:40 GMT
No problem Carl, pm me your mobile number and i'll text you
Post by carlyd on Apr 1, 2015 13:27:17 GMT
I've fitted the engine. It literally took 30 minutes on my own. I was very surprised how easily it went in. I've almost done the cooling and am now on with the wiring. Many Thanks to Deano for advising and lending me a genuine Honda wiring diagram. I think I've figured it out so I'll post pics of the wiring as I'm doing it.
Post by carlyd on Apr 10, 2015 9:43:32 GMT
Well after a few days of trying to figure out the wiring I'm lost so decided to do something else. Fitted my floor with M4 rivnuts and bolted it on. Finally got my drivers seat, I had wider ones made in GRP so I fitted that (still waiting for the second seat to be made). It doesn't look that wide but it's right on the limit of what is possible to fit in the rocket. In fact it's probably a liitle too wide for the rocket so I will have to custom make my center tunnel. I used the crush tube idea as used by other builders. I used some steel bar with M12 OD and M8 ID. I then drilled the M8 hole all the way through and then widened the top of the hole with a 12mm drill bit. Bolted in place with an M8 bolt, works a treat.
Post by carlyd on Apr 10, 2015 9:44:45 GMT
Seat runner and floor fitted.
Post by carlyd on Apr 10, 2015 9:46:11 GMT
I've also fitted the front floor and radiator area side panels, so here is the car at the moment.
Post by BobN on Apr 10, 2015 9:49:39 GMT
Looking real nice. I esp like the gear lever position.
Post by carlyd on Apr 10, 2015 9:51:05 GMT
After a long time trying to find wheel and tyres that I like and that fit the hubs (it's quite a limited range) I chose these Momo Hyperstar 16 inch alloys. with Yokohama tyres Only one problem, the courier managed to drop one of the wheel damaging it and my 4 wheels were the last 4 in the UK. So momo have flown one over for me, which will be with me by Monday. (damaged wheel below)
Post by carlyd on Apr 10, 2015 9:51:49 GMT
So it's looking like this with 3 wheel on.
Post by rocketfella on Apr 12, 2015 18:22:41 GMT
Hi nice build im currently looking at building one myself and going down the same engine route as yourself and was woundering how you got round the gear change problem? Would have messaged you this but cant seem to work it yet.
Post by carlyd on Apr 12, 2015 22:13:02 GMT
Hi nice build im currently looking at building one myself and going down the same engine route as yourself and was woundering how you got round the gear change problem? Would have messaged you this but cant seem to work it yet. Hi, what exactly do you mean by gear change problem? I'm just having new gear change cables made as the current ones are not long enough.
