Post by JIDiesel on Nov 22, 2014 5:52:04 GMT
I have been in the process of stripping my harness for the car. I am a bit stumped here, I have no idea what these relays go to. Any ideas? They were located on the driver's side of the main harness under the hood near the shock and air filter box. They had black rubber boots covering them when I removed them. The second is this box. Any ideas what it goes to. located on the main harness under dash drivers side. This is from a 2000 NB_ USA Model. Thank you in advance for the help. It is almost 1 AM, I am going to bed now. we will see what tomorrow brings.
Post by gwnwar on Nov 22, 2014 7:17:35 GMT
Two relays for AC and Condenser fan.. large is Cruise control module..
Post by JIDiesel on Nov 22, 2014 15:53:58 GMT
Two relays for AC and Condenser fan.. large is Cruise control module.. Thank you, for your help. John
Post by JIDiesel on Nov 24, 2014 1:01:25 GMT
Are these blank sockets needed? What is this for? was located behind the drivers seat near the seat belt. The wiring diagrams for this car are such a pain. Well not everyone uses Bosch wiring protocol. Again thanks for the help in advance.
Post by gwnwar on Nov 24, 2014 6:41:26 GMT
Condenser for rear defroster system.. Another part for the round file..
Post by JIDiesel on Nov 27, 2014 23:54:06 GMT
Be careful removing the blank socket boxes they double as wire jumpers. Having harness spaghetti for Thanksgiving.
Post by JIDiesel on Dec 8, 2014 3:02:41 GMT
Found a creative use for the window washer/ wiper control stalk. I plan on running secondary fog lights. I found that the wiring from the wiper stalk would work fine to run the relay trigger on the for lights. Also plan on using the OEM fog light switch to run the rear fog/ race light that I am installing.
