Post by jgilbert on Oct 3, 2014 21:17:49 GMT
Makoto,
I'm liking you light positions. The wider the better for me. Makes the rear look mean. Sorry can't help with the wiring.
Post by biggunz on Oct 4, 2014 7:50:37 GMT
So made some adjustments based on the feedback. I went for Nitrams idea....thanks. Surely Mr IVA will be happy with this..... Two other question; how do I wire the rear/brake lights?There are 3 wire from the donor and 2 on the mev lights? I use the earth from the donor, but where does it go on the light unit? Also ,as its an import, do I take foglight feed from the rear lights then to the switch? thanks For the tail/brake lights I soldered a ground wire to the light housing. For the fog light I used a fog light switch module, which is spliced into dipped/main beam wires with two wires run to a switch and a single wire to the fog. It's IVA manual is worded poorly on this subject and causing a lot on confusion. Shaun
Post by makoto on Oct 5, 2014 19:08:32 GMT
Thanks chaps.@jgilbert I do like the horizontal look better...
