Post by R2S on Mar 10, 2014 18:55:30 GMT
I planning to remove the ABS from my Mk2 1800 donor when building my Replicar but need some guidance.
Anyone know how to do this, I assume I'll need a balance valve for the front brakes?
Post by gwnwar on Mar 11, 2014 4:03:58 GMT
R2S.. You will need a different master cly. and a proportioning valve and hard lines between the two.. You can pull the wires out for the 4 speed sensors and remove them and take the tooth rings off the 4 wheel units.. Just follow a wire layout for which to pull and cap..
Post by R2S on Mar 17, 2014 23:36:04 GMT
Might be simpler to install the abs system and if it works ok with the new rolling diameter keep if not simply remove fuse?
Will probably use donor wheels for IVA so abs should work fine.
Post by gwnwar on Mar 18, 2014 5:50:18 GMT
I thought I read they don't check cars with ABS.. you have to tell them it is on car..If I am wrong please chime in on that..
