Post by davef on Jan 12, 2014 20:39:18 GMT
Can anyone help? the gear cable is catching on the chassis rail under the mounting, has anyone else had this or is it because my gear cables are from the MTX75 box?. I can either grind away some of the plastic surround on the cable end or raise the whole mount ? Similarly I fitted the handbrake lever and the cables won't reach the plate that the cables feed through, can I get a longer front part of the cable, the bit that fastens through the lever itself?
Post by airforceone on Jan 12, 2014 20:49:32 GMT
You can raise the gear stick mounting up by just putting washers under it. I think I just used a nut in each corner to raise it 5 mm or so.
Post by davef on Jan 12, 2014 21:05:44 GMT
I thought that wold be the solution, just wanted to check I hadn't missed something really simple and the fact that the cables are from the MTX is on the back of my mind. I hadn't noticed anyone else with the issue either. Any thoughts on the handbrake cable issue?
Post by davef on Jan 26, 2014 19:44:05 GMT
Decided to mount the ECU in the side void ala Daydreamer's build, I want to keep the engine bay nice and neat. Thinking about putting the fuel tank up front in the void that could be a useful storage area and putting the battery behind the passenger seat? Any thoughts?
Post by davef on Feb 9, 2014 22:16:53 GMT
Post by davef on Apr 12, 2014 15:37:32 GMT
Thought you might like my heat shields? Extra pulley installed and a few other photo's to bring the build up to date. Feel free to look at the build on photobucket The engine is now ready for installation Bracket for hydraulic fluid, needs to be power coated Front end coming together despite the poor state the threads were supplied in. Still onwards and forwards albeit slowly!!
Post by martinw on Apr 12, 2014 17:10:01 GMT
Looking good Dave . One point - it's worth considering extending the mounting point of the belt tensioner with a piece of flat bar. I haven't got a photo of mine, but daydreamer put one up not so long back: linkIt means that you get better tension on the belt than with the original positioning. Martin
Post by drbrian on Apr 13, 2014 21:20:30 GMT
I did the heat shield a bit diffrently, I am using a double spacing on the back firewall, which is vented to let the heat out. Next I will put reflective heat mat on the inside of the firewall and the outside facing the headers. Your version is very slick too.
Post by davef on Apr 23, 2014 18:59:07 GMT
Post by drbrian on Apr 25, 2014 2:25:12 GMT
Oh blue is so pretty!!! Where are you located Dave?
Post by davef on Apr 25, 2014 7:19:59 GMT
Albrightonn Shropshire, in the West Midlands
Post by andybaird on May 6, 2014 21:16:30 GMT
Hi Dave
Hope you had a good time at Stoneleigh at the weekend. One of the questions you asked was about the size of the Master Cylinders. I was looking at the connections I have for the Master Cylinder's and the sizes are 7/16'' unf Banjo's and bolts for the inlet and 3/8'' unf male connectors for the outlet.
Hope this helps Andy
Post by howard on May 7, 2014 9:40:12 GMT
hi dave can you tell me what additional pulley you added to the Engine please once the power steering and Aircon pump are removed the serpantine belt routing does not work.
You seemed to have solved this, so what did you use please and what belt did you fit, any photos of how you mounted this as well would be useful
Thanks
Howard
Post by mawdo81 on May 7, 2014 10:12:15 GMT
Post by davef on May 7, 2014 13:51:44 GMT
Hi Howard, I'm at work but I can put some pics up later. The easiest way is to buy the bracket from RTR and I can send you the part number of the pulley
