Post by mawdo81 on Sept 28, 2015 19:54:58 GMT
Well you're welcome to borrow mine if it helps you diagose
Post by p5curly on Sept 28, 2015 19:56:33 GMT
Lol I could pick it up another excuse for a drive out
Post by BobN on Sept 28, 2015 20:05:17 GMT
I have a matching key. One currently used to start the car but the other spare one which you can take as it goes with the ecu or you can take both keys and make me 2 duplicates without the transponder as I don't need the transponder to start the car as I have the dynotech ecu and a separate immobiliser.
Post by davef on Oct 1, 2015 15:58:30 GMT
Hi Bob, I'm thinking it might be the ECU could I try your spare with key please? Do you know if the PATS collar has to be changed or does that just sense the key code?
Post by BobN on Oct 1, 2015 19:24:42 GMT
Yes you can have it. I don't believe the PATS collar needs to be changed as I read its only a reader, the code is in the rfid. Found out you can also extract the module from the keys so that we don't need to exchange keys and mess with changing ingnition barrels. To do it was quite easy, put a thin blade on the edge of the blue part of the key and gently extract the entire module casing then take out the chips. Below is the module for my orginal Ford key (capsule RIFD) and the clone keys (chip RFID). If the ECU works then just slot these into your keys. Bob
Post by davef on Oct 2, 2015 17:55:21 GMT
Thanks Bob I'll let you know when I'm coming over to collect
Post by p5curly on Oct 2, 2015 18:26:19 GMT
If you need any help Dave let me know
Post by davef on Oct 2, 2015 21:04:12 GMT
Thanks mate, much appreciated
Post by andybaird on Jan 3, 2016 19:14:08 GMT
Hi Dave
How did you get on with your Sonic after the Skegness trip. Have you got it sorted and if so what was the issue.
Cheers andy
Post by davef on Jan 4, 2016 20:37:45 GMT
Hi Andy,
car are running really well, the Skegness problem turned out to be the cable to the crankshaft sensor shorted out due to heat degradation. All sorted and protected from heat in the future. I'm thinking of putting some cooling slots in the front edge of the engine cover, above the rear bulkhead as the engine bay does get very warm.
Post by andybaird on Jan 4, 2016 21:27:29 GMT
Hi Dave
Good to hear it's all sorted. I put extra vent on top of engine cover after I got it back from IVA as I thought the engine bay got to hot.
Andy
