balders1973
Junior
Grin inducing Turbo fitted :)
Post by balders1973 on Jul 2, 2013 14:42:36 GMT
Does anyone have a recomendation on where to get this stuff? I have seen so many different types / prices i'm going blind!
What have people used successfully so far ?
Thanks All.
p.s. it's for Rocket side panels / bulkheads / and probably tunnel.
Post by tomaff on Jul 2, 2013 16:24:48 GMT
We buy lots of this stuff through work. Go direct and get if from Hexis. item number HX30CA890b, which is the Carbon fibre black wrap. There are lots on ebay but this stuff is the top quality. The other vinyls are generally just be a cast vinyl that is not meant for wrapping (ie. going around bends) and this will warp and deform if you try it. Get some of this and heat it very gently with a hairdryer or heat gun. use a firm felt block (or squeegee in the industry) to apply pressure curing it to the surface. Work from the center out to avoid air bubbles. It will then stretch around a curve giving a seamless finish. As it cools it contracts and goes brittle, foaming the shape of the body panel Off the top of my head it is about £17-18 per meter at 610mm width. Rated to 10yrs We deal with lots of this stuff and it pays to get a good product. Hexis UK - 01543 411221 www.hexis.co.ukNot sure if you can order without an account but worth a go. Failing that I can a roll on our account if there are a few interested? they come in 30m rolls. T
Post by tomaff on Jul 2, 2013 16:29:46 GMT
Post by hightower on Jul 2, 2013 17:50:17 GMT
Now that does look like quality stuff Defo worth paying a bit more for a top finish.
Post by airforceone on Jul 2, 2013 18:26:20 GMT
I would definitely pay more for quality vinyl if I was putting it on areas that were not going to be soaked, covered in oil,coolant and fuel but unfortunately thats what is going to get on it if you put it on the floor and bulkheads, I'm speaking from experience.
At £20 a metre it's too good for that. I bought a 5m x 1.6m roll from ebay and it cost £50 including postage. And to be honest it looks really good, can be heated to smooth out wrinkles and forms round corners nicely. I've put it on my bulkheads, tunnel and floor. If it gets damaged I'm no too bothered.
If you have the cash and are willing to pay for the good quality stuff it will look good.
balders1973
Junior
Post by balders1973 on Jul 4, 2013 13:06:08 GMT
I would definitely pay more for quality vinyl if I was putting it on areas that were not going to be soaked, covered in oil,coolant and fuel but unfortunately thats what is going to get on it if you put it on the floor and bulkheads, I'm speaking from experience. At £20 a metre it's too good for that. I bought a 5m x 1.6m roll from ebay and it cost £50 including postage. And to be honest it looks really good, can be heated to smooth out wrinkles and forms round corners nicely. I've put it on my bulkheads, tunnel and floor. If it gets damaged I'm no too bothered. If you have the cash and are willing to pay for the good quality stuff it will look good. Thanks for the advice guys. I think I am going to follow the cheaper route. Not trying to build on a shoestring, but i'm not sure I can justify the additional expense! Should it turn out rubbish (After all it's me applying it) then I've not lost too much cash. If it's a good job then maybe i'll keep it untill I can afford real carbon fibre....ROFL
